This may be a corrupt OS try removing the ram module (First remove all power sources including batteries) then clean the connection of the RAM modules using a pencil erraser replace them very carefully then reboot if this does not help buy a USB IDE connector converter you could basically open all your files in another computer to do this you need to remove your lap top hard drive buy the compatible USB IDE or SATA which ever fits you hard drive then connect it to a PC like using a USB Flash disk or Card
You have to be the computers Administrator to change any values on any hardware on a computer
Click start control panel user accounts on the users tab click the name of the computer Administrator you must have full control.
Click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
If you are running a Windows XP OS then you might be able to:
click start right click on my computer select open
Right click the icon of your Flash Drive (It should be F:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
w7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for xp or earlier
click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver
If now you can see your usb drive there might not be any need to do the following
Click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
then you might have restore it to its default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
Transcend jetflash recovery
JetFlash Online Recovery is an advanced new software tool specifically developed for Transcend JetFlash USB flash drives.
If your flash drive is not working properly, in most cases it can be repaired instantly by using the recovery tool's simple user-friendly interface.
The JetFlash Online Recovery Tool is conveniently located on the Internet, so no matter where you go, you can service your flash drive 24 hours a day, 7 days a week.
All data on your JetFlash drive will be permanently erased during the repair process.
Please backup the contents of your JetFlash before proceeding.
This software is designed to repair malfunctioning JetFlash USB flash drives.
It will not recover
any data/pictures stored on the device.
Hardware Requirements: USB Port (supports USB2.0), Internet Connection
System Requirements:
Windows XP SP2/ 2000 SP4 or later version(Administrator rights required)
Windows Vista (Administrator rights required, must turn off UAC) To turn off UAC in
Windows Vista, please go to Control Panel > User Account -> Turn User Account Control on or off > and then uncheck ''Use User Account Control to help protect your computer.'' Please remember to restart your PC for the new settings to take effect.
Windows 7 (Administrator rights required, must turn off UAC)
To turn off UAC in Windows 7, please go to Control Panel -> User Accounts -> Change User Account Control Settings -> change to "Never notify" -> then, Please remember to restart your PC for the new settings to take effect.
Download Links
JetFlash Online Recovery (for Windows 2000 SP4/ XP SP2/ Vista /7)
JetFlash Online Recovery (Only for V15; for Windows 2000 SP4/ XP SP2/ Vista /7)
JetFlash Online Recovery (Only for JF620; for Windows 2000 SP4/ XP SP2/ Vista /7)
User Manuals for JetFlash Online Recovery
If you need more help with this post a reply
Transcend have a lifetime warranty
Hope this helps.
