You can remove write protection from your drive using the below method:
Open start menu, in the search bar type regedit and press enter. This will open the registry editor.
Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Note:
If the registry key Storage Device Policies does not exist, you will need to create it manually.
Double click the key Write Protect in the right window and set the value to 0 in the Value
Data Box and press OK button
Restart your computer and try copying files into your USB drives.
or you might
click start click to open on my computer you should see your usb drive E: right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
hope it helps
Open Symantec.com and download Norton2007(Anti Virus) or u Can Try With E-Scan (Antivirus)
Gizmo1
