Hi
I have a HP 3380 Printer which is working fine. My issue is it answers all incoming calls (both voice and fax). Is there a way to enable it to answer incoming faxes only. I want all voice calls to go to messagebank if the phone is not answered. The fax machine should not be answering voice calls.
There is an option "Answer ring type" with the following options:
Single, Double, Triple, Double and Triple, All Rings
Do incoming faxes use a ring type different to voice calls?
Any ideas on how I can configure the fax to answer faxes only?
Thanks
Anthony
If you have call waiting on your phone service you can call your phone company and get "personal ring" service. It will cost a couple of dollars extra a month, but they will assign you another phone number and it will have a different ring style to it. Then you can set the ring type to the type of ring they assign you.
To make sure the printer picks up
incoming faxes, set Auto Answer to On, and then set the printer to pick up
after a greater number of rings than the answering machine. For example, if the
answering machine picks up calls after four rings, then set the printer to pick
up after six rings. This way, the answering machine picks up calls first and
your voice calls are received. If the call is a fax, then the printer detects
the fax signal on the line and takes over the call.
If you have a voicemail feature associated in the same line as your fax:
Voice mail and fax can share the
same telephone line if you subscribe to a distinctive ring service offered by
your telephone company. This feature allows you to have multiple telephone
numbers on one telephone line. Each telephone number has a designated ring
pattern (single ring, double ring, triple ring, or double and triple ring). The
different ring patterns let you know which telephone number was dialed, and
which device you should use to answer the call.
If you do not have distinctive ring service, then set the printer to receive faxes manually (Auto Answer Off). This setting lets you receive both voice calls and fax calls, but works best if you use voice mail more often. You need to turn off voice mail whenever you are expecting a fax.
If you have an answering machine connected to the same line as your fax:
If you have a voicemail feature associated to the same line as your fax:
expecting a fax.
I hope this helps.
Should you need further assistance, please contact Lexmark Technical Support Center.
