Monitor screen changes from regular color to a green tinted screen?
When i use computer the slightest movement makes my screen turn a greenish tint,,,i can still see the page..but it,s greenish.and it goes back and forth from regular color to green...help???
monitor works but everything is has a blue/green tint. tried turning it off and back on but that didn't help.monitor works but everything is has a blue/green tint. tried turning it off and back on but that didn't help.
You can't post conmments that contain an email address.
Re: monitor screen changes from regular color to a green...
Is the cable connected securely? You may need to check your video card also. You may be able to disconnect the cable and get a red, green, blue icon on the screen. If that appears normal then there is nothing wrong with the monitor itself, it may be the cord or the video card.
Try a different video cable or make a careful inspection of the pins in the video connectors. Look for bent or missing pins. Your missing a color channel.
Make sure you did not bend any pins also make sure of that fact on both ends if not there has to be a solder connection inside that has faultered on you. The unit will need to be opened up to verify solder connection- Thanks
Looks like you need to purchase a new monitor. If it's too worn out then it's the outcome. I also had the same problem before and I ended up buying a new one. You should not experience that thing if it's new.
The instruction manual should tell you how to get into the menu for the monitor to change the color settingts. With a make and model number I can give you step-by-step instructions on how to change them.
if your monitor has color controls try them,if your monitor has auto adjust try that too.if you can test the monitor on another computer try that as well to verify the monitor is causing the problem.if none of this works its safe to assume that the color control circuitry in the monitor has failed and with todays monitor prices it is cheaper to replace than to repair.
