Computers & Internet Logo
Posted on Oct 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dsl-2740b router connections freezes - D-Link Computers & Internet
DocLab
Level 2:
Novelist:
  • D-Link Expert 199 Answers
  • Posted on Jan 06, 2017
DocLab
D-Link Expert
Level 2:
Novelist:
Answers
199
Questions
0
Helped
123438
Points
205
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
5 Related Answers
aysaam
Resolution IT Dubai
  • 541 Answers
  • Posted on May 29, 2009
SOURCE: Trouble installing
Initially check wither u can ping from ur PC the ip 127.0.0.1(go to start--->run---->type cmd---> in the black screen type ping 127.0.0.1).If u got the reply then the nic card is installed properly.
The wire connectivity should be as follows,
1.Connect the RJ 11 to phone pine jack at the back side
2.Connect the PC to the other any one of the Port and try to login in to the router with the help of the browser 192.168.1.1.
3.U will get the page of the router and try to configure the ip address in hte particular columns
4.If its dymanic then once u have connected u will get the internet.
Regards,
Ayyasam
Anonymous
  • 854 Answers
  • Posted on Aug 16, 2009
SOURCE: connect netgear wpn824 to DSL router using usb connection between
call your ISP. Change the DSL modem from USB connect to ethernet connect. There is no possible way two match the two device
Anonymous
  • 404 Answers
  • Posted on Sep 01, 2009
SOURCE: No DSL internet connection following router install.
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. Dont use the setup cd, sometimes it works, sometimes its not. here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
if you have any querry pls feel free to get in touch.. good luck
Anonymous
  • 6 Answers
  • Posted on Oct 05, 2009
SOURCE: my wireless doesnt broadcast. im using a dlink dsl
Under your wirless tab. Make sure Enable AP is ticked. You have named your SSID, usually the same name as your workgroup network.
In windows your workgroup is called WORKGROUP.
Chanel is set from 1 to 13
Security is set to WEP
Authentication Type is set to OPEN
Encryption key password is set to a 10 hexadecimal code.
ie: abcde12345 ( choose something you will remember)
On the device you are recieving make sure you have the same password, SSID, Same chanel as router and is set to WEP. If they are not the same then the units will not connect.
This should resolve your connection. When you first connect have the two units close to each other and reset the router. Then reset your other device. If it does not connect chect the antenna is screwed in firmly but not too tight to the router.
If it still fails then change your chanel up or down on both devices. Does not matter what channel you choose just as long as they are both the same.
Anonymous
  • 98 Answers
  • Posted on Apr 15, 2010
SOURCE: setup of d link dsl-2740b on my computer
the dsl connection is your broadband signal. check the router box. if the dsl light is off or flashing on the front, the setup will not work. this light needs to be solid. remove all devices from telephone sockets in your house, connect just one filter and your new router to it. check the dsl signal, if the light is solid green. the problem is with the physical setup in your house. If the dsl light still flashes contact your isp or broadband supplier.
Need a installation cd for d-link dsl-2740b
Hi you can visit this site . Its provides full support for your modem and stuffs . STill unsure or not feeling right . Message me or in fixya .. The experts here will be of great assist.
Link Technical Support
Every site you visit or download its at your own risk . Please make sure you have an anti virus or firewall . I shall not be held responsible if any mishaps happens if you were to download or visit any link provided . Thank you .
1helpful
Internet light on modem is solid red
How about the DSL light?
If its solid green then your problem could be a mistyped ISP username/password in the router, or your subscription expired.
Problem with modem router DSL-2740B
1.Reset-
The factory reset button is located in the back panel of therouter, and requires a thin, sharp and robust object (like anunfolded paperclip) to be pushed in.
To factory reset, power up the device and wait for 1min. Pressand hold the reset button until the STATUS LED turns off. Releasebutton and wait 1min.
2.Update the firmware-download the required files from the D-Link Support page
3.Contactct your ISP
Password into a D-Link DSL-2740B Router
Try "admin" as name and blank password. If this won't work, your router might have a set username and password and if you don't know it, You might need to reset your router then try the credentials I gave you.
Be reminded that if you reset the router, you will lose all current settings you have and it will revert it to factory default settings.
Visit my tips and tricks for more info on how to access your router. Click here.
Hope this helps.
My D-Link DSL-2740B modem Router is already installed and working for all the computers but trying to hook up the Vista OS computer and wireless access is asking for to enter 8 digit PIN. I can not find 8...
Well the PIN number is Usually on the router itself on the back side and its a 8 digit number if that works well and good. Open an Internet Explorer browser page on your wired computer(desktop).In the address bar type - http://192.168.1.1 and press Enter... Leave Username blank & in Password use admin in lower case...8 Dec 2011
Need PIN number! - Networking, Internet, Wireless Forum ...
en.community.dell.com/support-forums/network-internet-wireless/f/3324/.../19426225..or go to this link and see if it helps you find were it is..... Link DSL 2740B modem Router pin number Google Search
2answers
Setup of d link dsl-2740b on my computer
3helpful
2answers
PPP Password doesn't match error
1. You should better check the power supply if it is plug on, properly on a 220AC Voltage. 2. After installing your disk suppose to be you should reset the configuration of your DSL 2740B so that it will restore back to the main configuration of the system. (to reset your DSL 2740B try to look for a small button on it. then press according to standards then your done. Good luck and i hope this steps will help you accurately. God Bless.
Driver
not sure why you will need USB drivers for your adsl2+ modem/ wireless router and 4 port LAN switch. It would help you had provided the model number.
The device uses a LAN ethernet port to connect to the computer. You will need atleast one computer to be on the LAN port for setting it up. Once setup is complete you can use wireless connection for every computer.
The user manual & drivers or the DSL-2740B which appears similar to your product description
http://www.dlink.com.au/tech/Download/download.aspx?product=DSL-2740B
Not sure if you need these. Your computers will need LAN or wireless drivers to connect to this DLINK modem/ router.
Good luck
My wireless doesnt broadcast. im using a dlink dsl 2740b router
Trouble installing
Regards,
Ayyasam
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
