SOURCE: No sound device in Sounds and Audio Devices after Realtek Sound Driver install
Download the attachment I found, unpack it into your folder of choice.
Then move over to the control panel and select that "PCI Device". Rightclick and install the audio bus drivers I provided for the PCI Device. During installation Windows should find something like Microsoft UAA Bus driver, I don't know the exact name. Do a restart after installation and everything should work fine.
http://rapidshare.com/files/85020543...On_1.0.7z.html
SOURCE: m2a-vm mother board
Hi auriaskate,
Currently you are using the onboard PCI video adapter. This graphics adapter uses you're system memory to function.
If there is a problem with you're system memory the beeps can lead one to think there is a problem with the onboard video.
You can not remove the onboard adapter so there may be a problem with you're system memory. (I doupt you're memory is bad) but on the other hand it might not be fully installed correctely. Power off the PC & unplug the power cord from the PC.
Please remove you're system memory & firmly reseat it.
Plug the power cord back in. Start the PC & listen for any beeps except the 1 normal beep known as P.O.S.T = Power on self test. Any beeps after that there is a problem with a device connected to the board.
You're Asus M2A-VM uses an Award bios. Click on the link below to see what Award beeps mean.
http://www.bioscentral.com/beepcodes/awardbeep.htm
Try the memory reseat & check. Let me know if this helped.
Mike
SOURCE: ASUS M2A-VM Motherboard is registering my GForce 7800
Did you disable the onboard video?
Click Here for review and comments regarding your board and video card.
SOURCE: M2A-VM random reboot
there is no windows xp sp3.all sp3 are made by hackers which used to hack the systems easily.so please change ur operating system and also uncheck the My computer(right click)->properties->advanced->startup and recovery,uncheck the automatically restary.
ur problem may be solved.
