From your observation it is clear that there could be only two glitches with your machine.
1. The print button on your machine has gone bad.
2. There is some setting issues.
In order to provide you with a successful solution I require you to connect your machine to a pc install its driver and give a print command from pc. That would establish that the button has gone bad. In case you do not get a print that would suggest settings problem.
kindly do understand this is necessary for cheapest rectification of your copier.
From all indication, I don't think there is something specifically wrong with your Kyocera mita 3035 copier, I think it's a minor malfunction. Resetting the Kyocera mita 3035 copier should put it to order.
This is also not a program setting issue. Reset the Kyocera mita 3035 copier and let me know the out come.
If you don't know how to reset your Kyocera mita 3035 copier, you can check the manual below, as there is a direction on how to reset your Kyocera mita 3035 copier in it.
The manual is in pdf format and it might take some time to load completely, so be patient till is loads fully.
http://usa.kyoceramita.com/americas/jsp/upload/resource/11864/0/PRTSCANSYS-U-ENOG-SETUP.pdf
Good luck.
Thanks for the advice. The PDF you sent is for setting the scanning mode. Our Kyocera is not hooked up to the computer for scanning. We use it solely for copying. I could not see how to reset it for the copying aspect in the manual I have. What you said is what I suspect is the issue. It is not set properly somewhere and I can't seem to find out where. Any other thoughts? Thanks again.
