The manufacturer has replaced part number 8268390 with part number 8531857. Manufacturer part number 8531857 is RepairClinic.com item number 1060487.
Welcome to FIxYa.com
THERMOSTAT REMOVAL HINT: Removal of the thermostat would have an adverse effect causing a lowering of cooling efficiency. Do not
remove the thermostat, even if the engine tends to overheat. 1. DRAIN ENGINE COOLANT 2. REMOVE AIR CLEANER CAP WITH AIR CLEANER HOSE 3. DISCONNECT ECT SW1TCH CONNECTORS 4. DISCONNECT ENGINE VIRE PROTECTOR FROM WATER INLET AND RH CYLINDER HEAD Remove the 2 nuts, and disconnect the engine wire protector from the water inlet and cylinder head. 5. DISCONNECT WATER INLET PIPE FROM WATER INLET AND LH CYLINDER HEAD a) Remove the bolt and disconnect the inlet pipe from the water inlet. b) Remove the O-ring from the inlet pip e. 6. REMOVE WATER INLET AND THERMOSTAT a) Remove the 3 nuts, water inlet and thermostat. b) Remove the gasket from the thermostat. INSPECTION INSPECT THERMOSTAT HINT: The thermostat is numbered with the valve opening temperature. a) immerse the thermostat in water and gradually heat the water. b) Check the valve opening temperature. Valve opening temperature: 80 - 84CC (176- 183 deg f) If the valve opening temperature is not as specified, replace the thermostat. c) Check the valve lift. Valve lift: 10.0 mm (0.394 inch) or more at 95CC (203 deg f) If the valve lift is not as specified, replace the thermostat. d) Check that the valve is fully closed when the thermostat is at low temperatures (below 40CC (104CF)). if not dosed, replace the thermostat. INSTALLATION 1. PLACE THERMOSTAT IN WATER PUMP a) Install a new gasket on to the thermostat. b) Align the thermostat jiggle valve with the upper stud bolt and insert the thermostat in the water inlet housing. HINT: The jiggle valve maybe set within 15 deg of either side of the prescribed position. 2. INSTALL WATER INLET Install the water inlet with the 3 nuts. Torque: 8.0 Nm (80 kgf-cm, 69 inch lbs.) 3. INSTALL WATER INLET PIPE a) Install a new O-ring to the water inlet pipe.
Thank you for using FixYa.com
Regards, Lee Davidian
I found an easy way to get the protector cover off. once the torx screws are out get a pair of angled needle nose pliers. insert the pliers into the water intake for the grinder, just a little, then gently rock the cover up, it should pop off with little effort.
