Navman PiN 570 GPS Receiver Logo
Posted on May 30, 2008
Pin 570 not charging
Never had a problem and then today it just wont charge.
Tried the three other chargers 2 car chargers and the mains one with no luck.
Could it be the battery?
Even if it is shouldnt it still be able to operate?
Down to 37% as I write this so enough to back it up.....I hope.
  • Will1985 Jun 25, 2008
    My Navman piN 570 will not turn on even with the charger plugged in. I have looked to ensure that my hard reset switch is too the right, but their is nothing there.
    I assume that this has broken off. but don't know if it broken off when at the left or the right?
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Nov 07, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
774
Points
The connect where it plugs in is very flimsy you may need a new one. try adjusting the angle etc at which you place the unit on charge its very fiddly to get it right and a small nudge loses it
My tablet wont charge when put into mains charger this is the second time my charger connection feels lose
which end feels loose, the dc socket on the tablet or the mains (240volts) end (three pin plug?).
If the mains end, you need you need to get a new charger, it is dangerous to continue using it.
If it is the dc socket end, there is not a lot you can do about it, as it is solder to the mainboard, unless you can unsolder it and insert a new one.
Have you thought about gluing the dc side into place, so it cannot move?
1helpful
TomTom Rider unit wont charge. Tried mains charger, USB connector and bike charger. Swapped out the battery and the unit boots up but that is just the charge in the new battery. Any help appreciated.
Power board is faulty, repair or replace. Workshop repair required. Oh, stop plugging a charger into the USB socket. It doesn'tlike it, thats for data transfer only. The round pin socket is the charger port
My voyager wont charge its brand new... only three weeks old and ive chaarged it before but now today i went to charge it and it wont work
If you have already tried using another charger, then the charging port inside your phone is probably either broken or bent. I wouldn't suggest trying anything to unbend it or fix it yourself; I would go up to the store if I were you. I had the similar problem, and I just got my refurbished (4th Voyager) in the mail today. But my most recent old phone did the same thing, and I had to get it replaced; I hope I helped some!
2helpful
Won't Charge
You need to change the battery. It is not a fun thing to do. Do a word search for Navman PIn 570 Replacement battery either on Google or Ebay. You have to disassemble the unit to get to the battery that is taped to the unit's motherboard. There are hidden screws on the back of the unit, then you have to gently pry the 2 halves off. Big Heads up here: the round dial on the left side...be sure to tape that in place when you first disassemble the unit, otherwise it falls out into 2 or three pieces...that dial is a pain to get back together if you do not tape it.
I recently replaced the battery on my unit. There are two additional screws on the back of the unit, near the bottom in addition 2 screws under the flip up antenna. They are covered by small black plastic discs which need to be pried off first. After removing the rear cover with a knife edge (or similar) there are several other screws which attach the circuit board to the front of the unit which need to be removed. Note that the one near the edge should only be loosened, and the board slid out sideways. Once this has been done you should be able to access the battery which needs to be pried off the board, as it is attached with an adhesive patch.
(If the battery is totally dead it takes about a day before the charge led starts flashing.)
1helpful
Pocket pc navman 1022 charger and charger jack pin
sir, i have pocket pc 1022 navman pin 570 is not connecting with my pc.
2helpful
2answers
Dell inspiron 1300 wont work from the AC adapter
Is the laptop working without the battery, directly on AC. Have you tried using another charger or battery to see if its charging.
Works off mains and battery but wont charge battery.
replaced the circuit board where it meets the battery
2answers
NAVMAN 570 PIN
maybe there is a flat or stuffed lithium battery or battery charging circuit in the pin 570.
fix:
leave unit to charge for 24 h
if the battery still dosnt charge because it is over discharged, then you may be able to push some charge in it after the battery is unplugged, after opening the case, and removing the circuit board
Not responding......help
Low or flat battery. Connect to mains charger and fully charge.
1helpful
Sony ericsson t610 is not charging
if the chocking coil that is placed bet charging fuse and charging input pin of UEM(universal energy management) is not working properly the set wont charge or else if protection anode is short circuited also device wont charge
Top Navman GPS Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Mike Cairns
Mike Cairns
Are you a Navman GPS Expert? Answer questions, earn points and help others
