Question about Vizio VP322 32 in. Plasma TV
WHAT IS THE DIFFERENCE BETWEEN 1080I AND 1080P AND WHICH ONE IS BETTER?
  • 2,574 Answers
1080i vs 1080p - Similarities and Differences Between 1080i and 1080p
How 1080i and 1080p Are Both The Same and Different
1080i and 1080p are both High Definition display formats for HDTVs. 1080i and 1080p signals actually contain the same information. Both 1080i and 1080p represent a 1920x1080 pixel resolution (1,920 pixels across the screen by 1,080 pixels down the screen). The difference between 1080i and 1080p is in the way the signal is sent from a source component or displayed on an HDTV screen. In 1080i each frame of video is sent or displayed in alternative fields. The fields in 1080i are composed of 540 rows of pixels or lines of pixels running from the top to the bottom of the screen, with the odd fields displayed first and the even fields displayed second. Together, both fields create a full frame, made up of all 1,080 pixel rows or lines, every 30th of a second.
In 1080p, each frame of video is sent or displayed progressively. This means that both the odd and even fields (all 1,080 pixel rows or pixel lines) that make up the full frame are displayed together. This results in a smoother looking image, with less motion artifacts and jagged edges.
Differences Within 1080p 1080p can also be displayed (Depending on the video processing used) as a 1080p/60 (Most common), 1080p/30, or in 1080p/24 formats. 1080p/60 is essentially the same frame repeated twice every 30th of a second. (Enhanced video frame rate.) 1080p/30 is the same frame displayed once every 30th of a second. (Standard live or recorded video frame rate.) 1080p/24 is the same frame displayed every 24th of a second (Standard motion picture film frame rate.)
For more detalis visit http://hometheater.about.com/od/televisionbasics/qt/1080ivs1080p.htm
Posted on Oct 09, 2010
4 Suggested Answers
6ya staff
SOURCE:
SpotBert
Suzanne
  • 231 Answers
SOURCE: i dont know if my lcd tv supports 720i, 1080i, or 1080p
Sorry. It does not. 480i and/or 480p.
http://www.generalmanual.com/Televisions/Sanyo-CLT1554-STEREO-LCD-TV-EDTV-Monitor.htm
Picture Resolution: 1024 x 768 (XGA);NTSC (480i) EDTV (480p)
Posted on Dec 24, 2008
John Riley
  • 441 Answers
SOURCE: Vizio VW37L
720p & 1080P are what you want, the vizio has a higher repair rate than most, check out the toshiba or the samsung
Posted on Jul 17, 2009
Anonymous
SOURCE: Samsung sold the LNS4695DX/X as a 1080P TV it only 1080i
Nothing broadcast in 1080p....nothing. You probably just need to set your blu-ray player to output 1080p most will default to low resolution. A 1080i max TV is very rare these days.
Posted on Sep 01, 2009
Can't get my movies to play in 1080i
Most high-definition movie recordings are in 1080p format. Your video player would have to send the video as 1080i before the TV will play it if the TV is set to 1080i. (Theoretically, 1080i would do better on high-speed action, but 1080p is less prone to odd visual effects such as Moire banding, so that is usually the preferred format, especially given the improvements in video processing speed over the last decade.)
Nov 25, 2011 | Vizio Televison & Video
What is diferent betwin 1920*1080p and 1920*1080I
Television pictures are a series of still pictures that are presented quickly to give the illusion of continuous movement.
1080p and 1080i indicate how these pictures are formed.
1080p is progressive scan. It is a format that "paints" the picture left to right, top to bottom. On older tube type screens, this would cause the top of the picture to be dimmer than the bottom, as the phosphers would fade before the next picture was painted.
1080i is interlaced scan. This format paints every other line from top to bottom, and then paints the lines it missed before moving to the next picture. This evens out the brightness.
If your TV is capable of 1080p, it is considered to be the best picture (but you probably won't see the difference).
Feb 04, 2011 | Audio Players & Recorders
1080i on tv and not 1080p
No. Most broadcasts are limited to 1080i. BlueRay discs and (now defunct HDDVD) are the only time you will see 1080p. I heard DirectTV may also be running 1080p soon (or already have the option). In any case, 1080p requires 2x the bandwith vs. 1080i. I assure you that unless you see them side-by-side, you will not notice the difference. You many not notice the difference when you do see them side-by-side. The broadcast controls the 1080i vs. 1080p (not a setting on your TV).
Nov 17, 2009 | Cars & Trucks
Jun 10, 2009 | Televison & Video
1080P video via HDMI generates awful interference
Your Plasma's native resolution is 720P. Go into the Blu Ray's output setup. you can choose 480p 480i 720p 1080i and 1080p. Set it for 720p that should clear up the issue.You may have to run Component directly to the TV since you only have 1 HDMI input and you can run Digital coax or optical to your AV receiver for audio. On a 50" TV the difference between 720p and 1080p using "GOOD" cables cannot be seen by the human eye. Above 50, yes it is noticeable.
Hope this helps.
May 22, 2009 | Onkyo TX-SR705 Receiver
Direct TV says that they will offer 1080p quality. Need update
1080I and 1080P is more than a software difference. It is a hardware difference in the TV's capability to display a progressive picture at that resolution, so no software update will be able to help you. The processors are only capable of 1080 Interlace, and the TV is only capable of 720 Progressive or 1080 Interlace at it's maximum performance.
Hope this helps you...
Jan 06, 2009 | Toshiba 42HP83 42 in. HD-Ready Plasma...
I have a sony 32 inch xbr TV (myt first non analog). HOw do you change the resolution from 480i to 1080i. What is the difference between 1080i and 1080p Thanks for your help. Maria
The resolution can only be change on your resolution source (ie cable box, dvd, etc). On your cablebox go to menu/setting->audio/video->output resolutions->and here you can change the setting. The main difference between i and p is how the video is scanned. I is interlaced, meaning you get the odd lines of video, then the even lines, and the picture may flutter but its better for fast action. P is progressive giving all the lines of video at once, better for still images, but slower of some tvs.
Dec 06, 2008 | Televison & Video
Code
Hi - Here is a description of a few terms that might help, especially if you're in the market for a tv. If this answers your question PLEASE rate this as fixed. If you need more help just add a comment and I'll be glad to assist you further. Thanks.
High definition television is the highest form of digital television. It has a 16:9 aspect ratio, which is the same as a movie theater screen. This is possibly HD’s biggest selling point. The other is the resolution. High definition is the best available picture on a television. It comes in three different flavors: 720p, 1080i and 1080p.
What do 720p, 1080i and 1080p mean?
High definition programs are encoded with a type of resolution: 720p, 1080i or 1080p. The number stands for the amount of lines embedded within the signal. The letter describes the type of scan the television uses to display the picture. The ‘i’ means interlaced and the ‘p’ means progressive.
Why does the amount of lines matter?
The number of lines on a television is important because it allows for greater detail in the image. This is a similar concept to digital photos and how dpi determines print quality. The type of televisions all of us grew up watching had 480 visible lines on the screen. By doubling the amount of lines in combination with the type of scan, HD essentially doubles the quality of picture.
Does it matter if the resolution is interlaced or progressive?
The type of scan is arguable considering the amount of lines for each HD format. Progressive scan is a better type of scan because it doubles the amount of times the TV displays the image per one second in comparison to interlaced. Still, the difference between 720p and 1080i is so minimal that is isn’t an issue at all. While 1080p is better than 720p and 1080i, very few programs are made in this resolution so it really isn’t a factor right now…and, it might never be.
May 12, 2008 | Durabrand DWT1905 TV
I can't get the 1080p resolution to my insignia tv. Anyone can tell me how to do it pleaes?
that's because the TV's are ahead of the technology. Cable TV does not broadcast anything in 1080P yet;
Feb 02, 2008 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
PS3 can not perform 1080P.
TV will automatically convert signal to 1080i ; it's all in the tvs chip.
There's not much difference really! If your not seeing any image and show no signal in that input;you will have to reset your PS3 and it should work...hope that helps!
Oct 26, 2007 | Samsung HLR6768W 67" Rear Projection HDTV
Vizio VP322 32 in. Plasma TV Logo
457 people viewed this question
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
Jerry Greenberg
Jerry Greenberg
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
