Car Audio & Video Logo
Posted on Oct 09, 2010
How to remove a factory fitted radio in a 1996 ford laser
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jan 04, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
831
Points
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 18, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
715
Points
Hi, I need code for radio in Ford Laser GL 1996. Code range is 4 digits long and a range of 1 to 6 numbers to choose from.
1helpful
How can I remove the radio from a 1996 ford thunderbird and in a radio with cd player
You should be able to purchase an installation kit that will allow this. You will need a special tool to remove the factory unit. The 4 holes on each corner are there to enable you to release the locks that hold the unit into the dash.
2answers
I have a 1996 Nissan Maxima with a factory Bose CD player / cassette and radio and it will not turn on what's the solution
Maxima Bose Radio ' eBay
www.ebay.com/bhp/maxima-bose-radio
eBay1995 1996 1999 Nissan Maxima Pathfinder Infiniti J30 Radio BOSE CD tape Player ...Will fit and work in these with BOSE audio package only:1995 - 1999 NISSAN .... 2006Nissan Maxima OEM Bose Cassette & 6 Disc CD Player Radio CR13B ...DESCRIPTION Unit is missing some bottons, 3 of them, this item has NOT ...
Nissan Maxima Bose Stereo ' eBay
www.ebay.com/bhp/nissan-maxima-bose-stereo
eBayWill fit and work in these with BOSE audio package only:1995 - 1999 ... 1996 - 2000 NISSAN Pathfinder. 2004 2005 2006 NISSAN MAXIMA FACTORY BOSE STEREO 6 DISC ... Factory NISSAN INFINITI BOSE Radio, Tape, and CD Player. ... 6 Disc AM FM Stereo Cassette Radio Bose OEM LKQ (Fits: Nissan Maxima).
Nissan Maxima Car Stereo Removal and Repair - YouTube
? 8:52
https://www.youtube.com/watch?v=RT-SZEfeA4Q
Sep 16, 2012 - Uploaded by Factory Car Stereo Repair
Factory Car Stereo Repair .... I have nissan maximal 05..the CD part turns on but the cd won't eject...should ... I have a 2005maxima non-bose radio system. ... my speakers is super in my 05 maxima but my cd player keeps on ...
Nissan - Factory Car Stereo Repair
How to remove a non factory radio from the dash of a 1996 ford f 350?
Not having any information on how it was installed, make or model of radio, I can't be of much help. You need to provide more information on what you've done so far.
1helpful
How do I remove an after stock radio from a 1996 Ford F 350 disel pick up?
Almost all aftermarket radios come out through the front. The radios come with two pieces of, best described, about 6 inch long pieces of flat metal about a half inch heigh. After removing the face plate one piece is pushed in on each side. This pushes the clip that holds the radio aside and you can pull the radio out of its housing forward and out. If you can get under the dash unhook and wiring to the radio first, and don't forget the antenna. Instead of the factory tool you may be able to use two flat dinner knives.
How to remove a factory fitted radio/cassett from a 1996 ford laser
A useful website for FORD radio removal instructions (and other makes)
CLICK HERE
2helpful
Please can you tell me how I remove the factory fitted radio in a 1999 ford Laser LX 1.6
U need a special tool set, avail from many parts stores like Napa
Installing after market radio need factory wiring diagram for 1996 ford f150
Try chrutchfield.It is easy to spend a couple of bucks for a adapter.Then you just wire the radio an plug it in to the factory harness.You can also try any local box store that installs radios,they will have the adapter harness.Well hope this helps.
Radio/tape deck keeps cutting out. clicking noises lo volume no volume. then turn it on days later and seems to work fine. radio or amplifier problem?
radio problem. very common of fords with factory radios. best to get a used one. or try your local best buy and see if they can give a factory fit. they are pretty big with air included in the housing. best of luck
1helpful
Facia panel removal to change radio
YOUTUBE HAS GOOD VIDEO ON FORD CAR
RADIO REMOVAL.
Top Ford Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Ngoro
Are you a Ford Car Audio and Video Expert? Answer questions, earn points and help others
