Samsung Digimax 130 Digital Camera Logo
Posted on May 29, 2008
Mac won't recognize my camera
When I connect the USB cord to my MAC the camera icon does not pop up as it does on my Windows platform computer. Help!
A
Anonymous
I am having the same problem - I think the camera may not be compatible with mac.  Have you looked for a mac download for the camera?
How to upload pictures by my usb
That really is a matter of if when plugged in to the USB port of the computer you are using, if computer you are using can recognize the drive.
If you are using Windows XP, check "My Computer" and you should see the Kingston USB jump drive showing as an device icon.
In Vista and Windows 7 select "Computer" and you should also see the USB jump drive listed as a device icon.
If you are using a Mac OS X computer with your Kingston jump drive, providing the drive has been formatted with the Mac OS Extended (Journaled) format, or the MS-DOS format (which is readable on both Mac and PC platforms), it will show up
in the Finder sidebar and on your Desktop.
Either platform however, to load pictures onto your Kingston is easy, all you have to do is either copy the pictures from there respective folder or location and either right click on the Kingston 2GB HD icon and paste the pictures.
Or you can double click on the Kingston 2GB USB icon and paste or drag the pictures into the open window of the Kingston 2GB USB jump drive.
That is honestly as simple as it is.
Now, on the other hand, here are a few steps, if you want to upload to an online resource which allows photo uploads from another source, namely your computer..
When you use the upload feature of that website or webpage to upload your pictures to, no matter whether you are on a Mac or PC, you simply have to click that uploader's Browse or Upload button.
Next, simply locate the Kingston 2GB USB jump drive in My Computer, (Windows XP), Computer (Vista , Win 7) or Devices and/or Desktop (Mac OS X).
Then start selecting and uploading your pictures onto that website or webpage with your Kingston as the source drive.
Yes, I have given you a number of options, but hopefully you will see the ease of using any of these methods, again depending on what computer operating system you are using, how easy it is to upload photos from your Kingston (DTIU3/2GB) 2 GB USB Hard Drive.
Regards,
-Mactechtrainer
3helpful
3answers
Nikon coolpix s210 will not connect to mac
I have a Intel Mac Powerbook running OS10.5.8
On a coolpix 100, the default setting is that the camera is charged by the computer through the USB cable. You need switch that OFF.
While the camera still does not show as usb device, you can access it through the Nikon transfer program AND through iPhoto
ez-pics
I cant upload my pics to my computer
How To Transfer images To Your Windows XP/VISTA PC P, td, li {font-family: arial, u; font-size:9pt; margin-top:0px;margin-bottom:0px; word-spacing:1px;} To transfer images from your camera to your Windows XP PC, follow these steps:
  1. Connect your camera to your PC using the USB cable.
  2. Turn your camera on, and then select the 'Computer' option on your camera.
  3. After you have selected the computer option, a pop-up appears on your PC informing you that Windows has found new hardware. Close the pop-up.
  4. Double click the 'My Computer' icon located on your desktop. The My Computer window appears.
  5. Double click the 'Removable Disk' icon in the My Computer window. The Removable Disk window appears.
    Note: The drive letter associated with the removable disk may be different depending on your system.
  6. Double click the folder names DCIM in the Removable Disk window.
  7. Find the folder named 101SSCAM. The images taken with your camera are in the folder.
    Note: Each folder in your camera contains up to 99 images. Once this limit is reached in an existing folder, your camera creates a new folder. The folders are labeled successively: 102SSCAM, 103SSCAM, etc.
  8. To copy the entire folder to your PC, right click the 101SSCAM folder. A menu appears.
  9. Highlight 'Send To' in the middle of the menu. A sub menu appears.
  10. Select 'My Documents'.
  11. Windows copies the folder into 'My Documents'. Depending on how many photos are int he folder, copying may take a few minutes.
  12. Double click the 101SSCAM folder in My Documents to access and view the pictures taken with your camera.
How To Transfer images to Your Mac PC P, td, li {font-family: arial, u; font-size:9pt; margin-top:0px;margin-bottom:0px; word-spacing:1px;} To Transfer images from your camera to your Mac, follow these steps:
  1. Turn on your Mac, and then connect your camera to your Mac using the USB cable.
  2. Turn your camera on, and then select the Computer option on your camera's screen.
  3. An icon appears on your Mac desktop labeled Untitled.
  4. Shortly after, a pop-up appears on your Mac desktop. Click 'Download All' in the pop-up.
  5. After downloading is complete, another pop-up appears containing the pictures taken with your camera.
Connection problem with Mac
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
I cant put pictures onto computer?
you have several options.
1. see first what operating system you computer runs.
if it is vista or mac, it will be recognized as unknown device,
look for SSCAM100 or DCIM folder. you will then see the camera files in that folder.
2. you should also download the cd driver, the cd that comes with the camera, to your PC. this will help the connection be proper.
3. if you're using desktop, try to connect the camera at the back of your tower. look for a USB port at the back of the tower and connect USB cord to it.
4. make sure you're using the proper USB cable, the cable that comes with the camera. for your S630, it is USB cable type 2.
5. also, make sure before you connect camera to PC, camera is turned off, when the USB cord is properly connected, that is the time camera should be turned on.
6. when unpluggin the camera to PC, make sure that you are safely removing the device from the PC so you will not have future connection problems.
hope my suggestions work for you.
COOLPIX CAMERA 5200
You might be more successful if you provided a little more information. Is your computer a Windows PC or a MAC? Have you tried connecting the camera to the computer via the supplied USB cable? Assuming you're using a Windows machine, you can simply transfer the images using Windows file services, without needing to install any additional software. When you connect the camera to the computer via the USB cable, Windows recognizes the camera as a removable drive and assigns it a drive letter (e.g. drive G:). An icon for the "drive" appears in your MY COMPUTER window. (a) You double-click on the MY COMPUTER icon - (b) double-click on the drive ICON that represents your camera - (c) locate the folder where the image files are stored - (d) and simply drag the folder to your desktop (or wherever you want the images on your computer's hard drive). If you don't know what I'm talking about, then you need help with basic computer usage. If you're having a problem with the USB connection (e.g. the computer doesn't recognize the camera) then you should provide some more details about this problem.
3answers
Why does my iPod appears on my computer but not in iTunes?
Laptop or portable connecting via USB? "See iPod not recognized when connected to Windows laptop over USB for more information. Your computer doesn't meet iPod system requirements Make sure that your computer meets the system requirements to use iPod for Windows. Your iPod displays an exclamation point folder or sad iPod icon, or doesn't appear in iTunes or My Computer If your iPod displays a folder with an exclamation point icon or a sad (unhappy) iPod icon on its screen, or if your iPod doesn't appear in iTunes or My Computer, follow these instructions to resolve the issue. Your iPod isn't formatted for Windows iPod for Windows Software only recognizes iPod for Windows. You cannot use iPod for Macintosh with a Windows PC. To see which platform your iPod is formatted for, follow these instructions. Your iPod isn't connected to a high-power USB port If you're connecting an iPod, iPod mini, or iPod shuffle to your Windows computer, make sure that you're connecting it to a high-power USB 2.0 port on your computer (not a low-power one such as the USB port on your keyboard or bus-powered USB hub). Typically, USB 2.0 high-power ports are located directly on your computer. Try connecting your iPod to another USB port on the computer (or to a self-powered USB 2.0 hub that's connected to a high-power USB 2.0 port on your computer) if the computer still doesn't recognize your iPod. Alternatively, if your computer has a FireWire connection, try using that instead. If you're connecting an iPod, iPod mini, or iPod shuffle to a Windows laptop computer through USB, connect the laptop to a power outlet before connecting your iPod. You're not using a WHQL-certified IEEE 1394 card If you have a FireWire (IEEE 1394) card installed in your computer and are using it to connect your iPod, make sure that the card is Windows Hardware Quality Labs (WHQL) certified. If it isn't, your iPod may not be recognized, or you may not be able to send music to the iPod. If you're not sure about your card's WHQL certification, check the inbox material that came with your FireWire card or contact the card's manufacturer. You can view a list of WHQL-certified cards on the Windows Hardware Compatibility List website. To view this: Go to the Windows Hardware Compatibility List website. Enter All Products in the ""Search for"" field. From the Product Categories pop-up menu, choose 1394 Controller. Click the Search Now button. Note: Windows XP information is not listed on the initial search screen, but is listed when you click on an individual card. You can also check the list of recommended FireWire and USB cards that have been tested by Apple with iPod and Windows XP. (Apple sells FireWire cards that are compatible with iPod at the Apple Store.) To rule out an issue with your FireWire card, try connecting a different FireWire device to the card to see if your computer recognizes it. Your connections aren't secure Make sure that there i
3answers
For Mac users "iPod does not appear in iPod Updater or iTunes in Mac OS X Under some circumstances, iPod appears in the Finder in Mac OS X, but does not appear in the iTunes Source list or does not appear in the iPod Updater. Symptom iPod's disk icon appears in the Finder, but it does not appear in the iTunes Source list or in the iPod Updater. Note: The iPod may appear in iTunes, but not in the iPod Updater. Important: If you are using iPod shuffle, you must have 10.2.8 or 10.3.4 or later to connect it to your Mac over USB. Other iPods require 10.3.4 or later Products affected Mac OS X iPod (5 GB) iPod (10 GB) iPod (touch wheel) iPod (dock connector) iPod mini - USB requires Mac OS X 10.3.4 or later. iPod mini (Second Generation) - USB requires Mac OS X 10.3.4 or later. iPod (Click Wheel) - USB requires Mac OS X 10.3.4 or later. iPod with color display (including iPod photo) iPod nano Solution iPod nano Certain models of single processor Power Macintosh G5 computers may show iPod nano mounted in the Finder but not recognized in iTunes. If this happens to you, try restarting your computer and Setting Energy Saver to highest performance and turn off hard disk sleep. If you have an iPod nano, but don't have a G5, then follow the other steps below. Mac OS X 10.4.x Perform an archive installation of Mac OS X10.4. Mac OS X 10.3.x Navigate to /System/Library/Extensions. Drag the iPodDriver.kext file to the Trash (you will be required to enter an administrator account password). Download and install the Mac OS X Combined Update 10.3.9. Restart the computer when prompted to do so by the installer. Connect the iPod. Mac OS X 10.2.8 and earlier To resolve this issue with earlier versions of Mac OS X, you'll need to delete one file and reinstall iTunes. Follow each of the steps below. Step 1 Delete the file using Terminal Warning: The steps below describe how to remove a file by entering commands in the Terminal application (located in the Utilities folder inside of the Applications folder). Users unfamiliar with Terminal and UNIX-like environments should proceed with caution. The entry of incorrect commands may result in data loss or unusable system software. Open Terminal (/Applications/Utilities). Type: sudo rm -R /System/Library/Extensions/iPodDriver.kext Press Return. Enter the administrator account password when prompted. Quit Terminal. Restart the computer (From the Apple menu, choose Restart). Step 2 Reinstall iTunes Download the latest version of iTunes from the iTunes download page. Install iTunes. Restart the computer after the installation has completed. Connect iPod. Step 3 Delete the iPod.plist file Remove the following file in the your home directory and launch the iPod updater again ~/Library/Preferences/com.apple.ipod.plist "
3answers
3answers
Why my iPod doesn?t appear in iTunes?
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
