Intel Wireless LAN Driver for Windows 7 (32) Posted Date: 2016-09-21 ' Version: 12.4.1.11.0 ' Size: 4.43M Atheros Wireless LAN Driver for Windows 7 (32/64) Posted Date: 2016-09-21 ' Version: 1.0.0.196.0 ' Size: 21.82M Atheros Wireless LAN Driver for Windows 7 (32/64) Posted Date: 2016-09-21 ' Version: 8.0.0.144.1 ' Size: 21.79M Realtek LAN Driver for Windows 7 (32/64) Posted Date: 2016-09-21 ' Version: 7.003.0522.2009 ' Size: 7.26M pls remove the back cover and check wireless card label and download the correct driver.
SOURCE: toshiba L455-S5000 HAD TO DO A SYSTEM
Windows 7 is one of the more secure versions of windows.
If you did whats known as a "factory" restore then the password will also have been reset to the default.
If you did just a staged restore back to a date when you were one of the users then the password should still be the same.
Windows 7 does offer you the option of making a password reset disc and if you did not do that then you would need to try log in with the admin account.
The default on most (but not all) is username = Administrator and the password is either empty or = admin or administrator
If that fails you could try by downloading UBCD or a copy of HIRENS boot CD
UBCD is here
http://www.ultimatebootcd.com/
This has password reset tools etc
Burn it on a clean computer and then boot from the CD itself to get access o the reset programs.
Hope you get it sorted
Bob.
SOURCE: Toshiba Satellite L455-S5000 turns on
Try external monitor, if it works then more likley the backlight inverter or the lamp is bad.
see www.insidemylaptop.com for example.
http://www.sparepartswarehouse.com/Toshiba,Satellite,L455-S5000,PSLY0U-03F02F,Laptop,Inverters.aspx
Please leave rating if it helps.
