Ok it leaks, but you never said where or how. Is it leaking from the bottom: Try replacing the wax donut that is between the floor pipe & bottom of toilet.
Is it just leaking in the bowel from the tank: adjust screw in tank to lower water in bowl. Also consider decreasing tank water: bend wire to plasic bulb or unscrew plastic bulb a little bit.
Is it leaking from tank of toilet: turn off water cutoff at wall behind toilet. Look under tank to see if water from seal or just loose bolts. If you have to replace those innards of tank. Home Depot/Lowes will give step by step instuctions. Take it to them and then will install free for you.
Leaks where?
where is the leak?
