GE (PSS26MSRSS) Side by Side Refrigerator Logo
Posted on Oct 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have read and seen many issues about the GE Profile Howling sound in freezeer area behind the ice maker. It seems very common and yet I have not found a TRUE fix for it. Is there a fix? Thanks dave Have GE Prolile PSS26SGRB-SS purched 11-27-2004
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 351 Answers
  • Posted on Oct 08, 2010
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
351
Questions
0
Helped
60672
Points
957
Yes a new board and fan motor have done this and it works ge tills you to replace them
Howling noise
Check the help link mentioned below:---
Click the link:--
Ice maker is noisy and not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-noisy-and-not-making-ice.html
These will help.
Thanks.
1helpful
2answers
GE Side by Side Refrig - loud noise behind the ice maker section Model PSS25SGMB BS
it sounds like the evaporator fan blade is hitting some ice that has built up around the blades i have seen this happen a lot on g.e. SxS lately,if you can remove the ice maker and dispenser you can see the fan blade,if you dont want to do this then shut down the refrigerator and leave freezer door open and heat it carefully with a hairdrier to speed the process up to melt this ice then restart it and the noise should be gone
4helpful
2answers
The ice melts from the ice maker forming icicles down below.
Just had this same issue repaired yesterday, the defrost element was out allowing the freezer to freeze up stopping the fan which moves the air and in turn causing the upper part of the frezzer to become warm and melt the ice. This is a common problem for the GE profile and I recommend finding a service company cheaper than GE and quit letting GE make more money off their CRAPPY appliances.
2answers
Me GE Profile PSC23M Side by side ice maker quit making ice and water was on floor behind refrig. Is a water line frozen or clogged or do I have to replace ice maker?
It sounds like you just have a leak at the back. Try swapping the wires on the dual water inlet valve. Then try the water dispenser and watch on the back for where the water may be leaking before it gets up to the ice maker.
1helpful
GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
Howling wind sound from the freezer/ice maker (extremely loud)
check the model # you post cannot find match there is a fan in the refrigerator section that some times make noise
Howling noise in frig
You need a new Fan motor . Or oil in the right place may do if it not worn by now.
2answers
GE GSL25JFR Freezer fan noise.
Replace the fan motor is my guess to cure the noise.
3answers
GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
I also had the same problem (gsh25jfta ww). It did that for a couple of months now the coils freeze up and fridge gets warm. Still looking for solution?
Top Refrigerators Experts
vince
Johnny 1000
