Question about Bosch Axxis+ WFR 2460 Front Load Washer
My Axxis 2450 (or 2460, not sure) washing machine will not spin. I cleaned the coin catch in the front, cleaned the drain hose (nothing in there really), cleaned the drain pump area (nothing in there), and the belt is fine and turning freely. I can hear some water draining when I put it on "drain," it's just not spinning. Help!
    New Friend:
  • 32 Answers
Check the drain pump
Posted on Dec 15, 2017
6ya staff
SOURCE:
Jimster
James Greene
  • 240 Answers
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Posted on Sep 09, 2007
Anonymous
  • 146 Answers
SOURCE: Whirlpool front loader washing machine (AWO3361) WONT DRAIN
Remove drain hose from where it connects to the plumbing under the sink/tub. Inspect the spigot. If clogged, clean. If clean, then tilt machine back and remove drum to pump hose from pump. Check hose and also drain pump. Clear any obstructions.
Posted on Nov 03, 2007
Priya darshan
  • 3422 Answers
SOURCE: WFL 2066 NOT DRAINING FULLY - NO SPIN
THIS LINK may help you understand what is actually wrong.
Goodluck,
Please don't forget to rate or accept the solution.
Posted on May 20, 2008
Anonymous
  • 435 Answers
SOURCE: Model 2100 about 4-5 years
Hi, from your description of the problems, it seems that the drainage valve is on. This is an electronic valve.
Seems that the valve is faulty and you may have to fix it. The best way is to get a technician to fix it.
It also explains the spin cycle problem, as spin cycle doesn't start untill all the water are drained by the drainage/outlet valve.
Posted on Oct 01, 2008
Carmen Mikulic
  • 415 Answers
SOURCE: My Bosch WFK 2401 keeps
hi there,
the 03 error message is the machine not sensing the water level. since you can drain using the pump manually, check the water level switch, as it may be faulty.
Posted on Oct 05, 2008
ASKO W620 QUATTRO 1200 RPM front load washing machine. This morning clothes were still very wet, I turned on spin cycle & some water came into machine?? Turned off water at tap - now can't open door to...
Probably a blockage in the drain hose at the back of the machine. Easy to fix. Turn machine off then pull machine out so you can easily access behind. Have bowls and cloths/rags at hand for water spillage. The drain hose is located low down and links into your sink drain, it is held in place by a clip. Remove the clip and hose. This will start to drain the machine so make sure you have enough vessels to catch the water. When the water has stopped draining, check the hose for blockages : buttons / coins / hair grips / paper etc. Also check the hole where the hose attaches to the machine. Remove items then blow through the hose to see if there are any other restrictions. If all clear then replace hose on back of machine. Clear up. Move machine back to normal position. Switch on and set to spin. When complete, the machine should shut off cycle and unlock door. This will save you at least 100 pounds on a call-out. Good luck.
Jun 18, 2014 | Washing Machines
Bosch wfl 2060 washing machine makes a funny rattling sound when it should be spinning or draining. why
Check the filter behind the flap (Bottom right of kickplate) souns like you have a coin or other foreign object in the pump.
Feb 18, 2013 | Bosch Axxis WFL 2060 Front Load Washer
My washer will spin but my clothes are still wet
Check to make sure you have no restrictions in the drain hose, and it has a loop in the hose like a horse shoe where the highest point of the hose loop is about in the middle of the drum. Shake the hose and listen for coins or foreign objects to make sure it is clean. Do you hear the pump motor during the drain cycle? Unplug the unit and remove the hose clamp next to the coin catch which looks like a rubber boot. Make sure the coin catch is clean and the impeller on the pump can move freely. If the impeller cannot move order a pump ($60.00). Last you will need to check to see if you have voltage on the pump during the drain cycle. If you do not order a pump and replace it.
Feb 23, 2011 | Frigidaire ATF6000ES Front Load Washer
UE Error, maching will not spin the clothes dry. Tried all regular methods for resetting, moving around the load in the machine etc. Nothing works
Remove the front cover at the bottom of the washer. Your drain hose and/or drain may be filled with sediment. I just cleaned mine and it fixed my no spin problem......also directions for doing so are in your manual. I used a large dog bowl to catch the water. If no water comes out of the drain hose after you unscrew the cap, squeeze it and see if gook comes out. Then remove the other cap (use a coin) and pull it out. Mine had years of dog hair, sand, coins in it. After I cleaned them, replaced them, spinning returned.
Mar 27, 2010 | LG WM-2277HW Front Load Washer
Machine won't spin
If water remains in the drum the unit will not go into the final spin. There may be a couple of reasons which I have experienced resulting in your problem. If water remains in the tub the unit will not go into the high speed spin.
1.) A coin or other foreign object is blocking the drain hose. Check the drain hose for foreign objects impeding the exit of the water. Shake the hose and listen for coins or a small object this unit will pass items through the pump into the hose causing blockage.
2.) The Drain hose is not raised above the machine outlet to create a siphon effect. See your manual for proper hose positioning. The hose needs to have a loop in it to work correctly.
3.) The pump is a third possibility which you should hear the impeller spinning during the drain cycle. There is a coin catch after the diaphragm of the pump that looks like a rubber boot that should be inspected for objects if you remove the pump. The pump is about $60.00 and is accessible after removing the front panel under the door. It is easy access from the front and the hose clamps will be the most difficult problem. I have a ratcheting hose clamp tool designed for this type of clamp but channel lock pliers will work.
Jan 18, 2010 | Frigidaire GLTF2940ES Front Load Washer
On the spin cycle the water will not drain
The problem is probably the pump being clogged with an object. Typically it is a coin.
Remove the front bottom cover to access the pump. Remove the two hoses. Make sure you have a pan to catch the water from the hoses. You will be able to remove the objects after the hoses are removed.
Jul 09, 2009 | Frigidaire ATF6000ES Front Load Washer
My washing machine gets to the spin cycle and will not drain. the message reads f03
Jul 04, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washing machine will not drain
I have a maytag washer that when it fills with water it wont drain out..the spin cycle just makes a noise and it wont do anything..any ideas what i can do to fix it thanks
May 07, 2006 | Indesit W 123 Front Load Washer
Bosch Axxis+ WFR 2460 Front Load Washer Logo
196 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
jimorris77
Dw Wooten
Dw Wooten
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
