The most common cause of an ELECTRIC dryer that will not turn on, is a blown thermal fuse or bad power cord. If the voltage at the wall receptacle is correct (220-240VAC), check the voltage again at the terminal block where it connects to the dryer. Make sure you UNPLUG the dryer and remove the the small access cover where the power cord is installed. Plug the dryer back in and take a voltage reading across the RED and BLACK terminals for the same voltage reading. If good, the problem is INTERNAL to the dryer. If bad, you need to replace your power cord.
NOTE: If the wires are not color coded, the two HOT leads are the LEFT and RIGHT wires. The center wire will be NEUTRAL or GROUND.
If the problem is internal, the thermal fuse will be mounted on the blower fan housing. It is a small plastic looking component (usually white in color) with two wires attached to it. Disconnect the wires before taking any resistance checks. If the fuse is good, it should read something close to zero ohms. If bad, you will read an infinite reading. These fuses DO NOT reset and must be replaced if bad.
Another cause of a dryer that will not turn on, is a broken door switch. An easy method to test the switch is to open the door and press by hand. If the dryer drum light is working, you should be able to toggle the light on and off. If the switch is found to be defective, it must be replaced.
Replacement parts can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and have competitive pricing, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations that you can use to locate and properly identify any parts you may need. If the model number is correct, the part number you may need are as follows:
The following link can give you some added advice on how to troubleshoot most common electric dryer problems:
http://www.fixya.com/support/r3574266-thorough_dryer_advice
If you have any questions about these repairs, or need instructions on how to access any of these components, please post back with your MODEL NUMBER and let me know. I hope this helps you.
