Computers & Internet Logo
Anonymous Posted on Oct 06, 2010
Having trouble connecting to an AT&T 2-Wire 2701 HGB Wireless Router (DSL).
  • Anonymous Oct 07, 2010
    Thank you, Prema -- however, I neglected to mention a critical detail: I can hook up with my laptop running Windows XP, no problem, but cannot seem to connect with my WiFi enabled Samsung S5560 cell phone. AT
Anonymous
Level 2:
Novelist:
  • Expert 125 Answers
  • Posted on Oct 06, 2010
Anonymous
Expert
Level 2:
Novelist:
Answers
125
Questions
0
Helped
62602
Points
385
Hi John,
I got your issue that you have trouble connecting with the At &t wireless modem ,
If Your comp if its win 7 Operating system
1. Click on start go to control panel--> go to
2. In network and sharing centre in the left hand side click on manage wireless network
3. In manage wireless network, you can see the networks which you have connected before , right click on the network name and select remove network. In the same way remove each one of them, the screen should me empty. there should be 0 items.
4. Then go back to network and sharing centre and click on connect to a network, you can see your network name , click on the network and click on connect to connect to the network.
If Your comp if its win Vista Operating system
1. Click on start go to control panel--> go to network and internet and then click on network and sharing centre
If Your comp if its win XP Operating system
1. Click on start go to control panel--> go to network and internet connections
2. Then go to network connections
3: You can see wireless network connection , right click on it and go to properties and go to the wireless networks tab
4. In wireless network tab, under preferred networks, if you see any network , remove it and then push ok
5. Then right click on wireless network connection and go to view available wireless networks
6. here you can see the network and you can connect with your password.
Please try this, im sure this will work
Thanks & Regards,
Prema
Can I use AT&T 2701HG-B 2W Wireless Gateway DSL
yes, you can use them together. they'll find each other at protocol layer 2 (bridge) and layer 3 (router),
and route packets appropriately. Check their manuals to make sure that their HTTP management page ip addresses are different - say 192.168.0.0 for one router and 192.168.1.1 for the other - so that you
can manage them separately without disconnecting them.
You'll want to manage them separately to assign them different wireless-N channels. Channel 6 is
the default, and allowing both to compete on the same channel is a bad idea - give each its own
wi-fi channel. There are 11 wireles 802.11n channels, labeled 1-11.
Diagram: DSL === AT&T 2701HG-B ---------- NetGear router --------------- desktop computer
Each link in the diagram above is an ethernet (802.3 10baseT) cable (except the DSL cable,
which is twisted pairs), and wireless devices can
hop onto the Internet by wirelessly connecting to either the AT&T 2701 or the NetGear router.
Will a 2 wire dsl router 2701HG-S work with cable modem
No, not the way you want it to. The wan(internet) port on the 2701 is an rj-11 that will only connect to a phone line with DSL service. There is no way to use this as a router with your cable modem. You need a router that has an ethernet (rj45) port as the wan port.
1helpful
2answers
Tell me about good adsl router
here some of best ADSL routers,
Linksys
Belkin
USrobotics
Prolink
regards
Krishan
2wire att dsl modem/router on vista
Connect your DSL to wireless router and enable automatic ip on wireless. check whether DHCP is enable in DSL router or not.
3helpful
4answers
Dsl
try opening a port your pc via the firewall on your router.
I'm having trouble hooking up my zonet wireless router. I put the cd in and did everything but it still wont work.
Are you running a DSL connection, or is it cable? If you have a DSL connection, the router IP and the DSL modem will conflict with each other trying to establish connection. This may be something to call zonenet customer support on to find out if it is possible to change the router IP address so they don't conflict. If you want to basically "PLUG and PLAY" return the zonenet router and get a D-Link wireless router. They are most compatable with DSL connections.
Linksys WUSB300N adapter not detecting wireless links
I am confused, you are using 2 routers, or you using their dsl modem/router? or your original??
Grand Canyon Tech
Grand Canyon Tech
