Compaq iPAQ MP2810 Multimedia Projector Logo
Posted on May 28, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
System shuts down
When I power up the projector I get the blue screen, then whit screen looking for input, the the light goes out and unit turns off. The whole process take 53 seconds. And it will repeat every time I try it. The air vents have been cleaned.
  • labiancad May 28, 2008
    All the fans are working, and all the LEDs were green. Then the unit shuts off and the back 4 lens go amber and quik flash.
  • Anonymous Jul 22, 2008
    When I power up the projector it stay on for about 53min then it will go off and after few second it will go on again
Anonymous
Level 2:
  • Expert 563 Answers
  • Posted on May 28, 2008
Anonymous
Expert
Level 2:
Answers
563
Questions
0
Helped
290459
Points
928
Hi labiancad
Were you able to see if all of the fans are working ?
Is there any of the LED's on the Projector flickering and what colour if they are ?
Acer projector blue light blinks and fan blows and no picture
As far as I can tell this looks like a lamp problem. Unless some of the fans are not able to cycle up tehn it would shut down before it overheats
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
2helpful
I have an HP VP6111 projector. It hasn't been used for about 6mths and now I try to power it on and the Blue light around the on/off button will light up for about 3 seconds and then turn off. I've...
Please do not unplug the power cord before POWER is shut down or during the two-minute cooling process.
If the projector is not properly shut down, to protect the lamp, the system will detect this and cool the lamp for two minutes automatically before turning on again.
Check that you are doing this.
I suspect that this is not your problem though.
It seems that the blue light doesn't flash very long. do any other lights come on during the startup process.
1helpful
2answers
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
2helpful
Projector turns on the power light flashing and lamp light solid
Here's the fix: Take off the top cover of the projector. Unplug the wire leading from the two fans in the back of the unit to one of the circuit boards in front of you. Just trace one wire from fan to board. Unplug at board. Turn unit on and it will again turn on, show HP splash screen and then shut down, like it should, because the fans are now disabled. After it completly shuts down, plug the fan wire back into the board. Turn the unit back on and, presto, its working again. It will not turn off.
Try it!
Unit turns on for 20-30 seconds then powers off.....Please Help
it is the ballast issue,u can try one of the equivalent ones or just try & rework on the old one, perhaps one of the mosfets is leaky!!!!!!!!
1helpful
PB6110 Powers down after 30s, splash screen appears, red temp lig
Be sure to check the filters and make sure you have good airflow thru the proj. Cleaning filters solved our temp shutdown problem.
Projector shut down
Hi
Replace the lamp, or better yet try removing and reinstalling the lamp.;
Hope this helps
Canon LV-S1 New bulb but won't power up
Have you cleaned the filters? In this situation, the fan and power shuts down even before the bulb lights up and heats up the unit, but perhaps the unit can detect clogged filters.
You can download the manual here if you don't have one. Instructions for cleaning the filters are on page 37.
1helpful
2answers
Green light flashing and then shuts down
Hi Gary
Have you resetted the lamp timer ? It must be done when a new lamp is inserted into the unit.
You can reset the lamp timer by holding the up arrow key on the Projector in until a online message appears. Then just follow the on-screen instructions.
If the problem persists , you will have to replace the Ballast wich is the lamp's power supply.
Top Compaq Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
