Question about Binks Paint Spray Gun Repairrebuild Kit Model 18
I am trying to make an external feed out of my binks model 18 i need to know exactly where to drill and tap on the air feed to do this
    Champion:
  • 248 Answers
Contact jason terrell at 270 389 0200 after 3pm
Posted on Oct 05, 2010
6ya staff
SOURCE:
My binks model 18 spray gun sprays inconsintaly on off on off ect.
this can be contributed to the seals around the needle part of the trigger operation
they get hard and don't seal properly
check gland seal nut for adjustment to place tension on the gland to make it seal
make sure that air bleed hole in the lid is clear and not blocking off
Dec 02, 2016 | Binks Air Tools & Compressors
I have photo copy of binks bbr spray gun with feed cup but i can't find it on your site. I don't know model no. please give me suggesion
The "BBR" gun was the predecessor of the MACH1 gun. And there are basically two versions of it. The older BBR version states on the gun "BBR" only and the newer version "BBR" and "HVLP". Most spares are the same. As I know they just called it "BBR" and there is no Model Number. I have both spare part lists (hard copy at the moment only). What are you exactly looking for?
Michael
email info@bsc-teknik.com ' www.bsc-teknik.com
Jun 01, 2011 | Air Tools & Compressors
I bought a spray gun and wanted to know the difference between the two air caps one is numbered 36SD and the other is 67PD I have a binks spray gun.
67PD PE Used for Zinc rich and other abrasive coatings, the 36sd is a general nozzle that is used for most applications, if you need assistance,, heres their number Technical Support Tel. 888-992-4657 Fax. 888-246-5732 or you can check their PDF located here . http://www.southernfluidsystems.com/BICONV.pdf
Apr 22, 2011 | Binks Model 7 Conventional Suction Feed...
My binks 18 spray gun squarts paint from the hole in the part that holds the cup on when i release the trigger
spray gun is cloged (clean it!) also check gaskets in gun and vent hole in cup lid ( could be cloged)
Jan 11, 2011 | Binks MACH 1 HVLP Pressure Feed Spray...
No suction
This model comes in either suction feed or pressure feed. For example a 6211-4307-9 is a suction model. There are different air caps and needles depending on feed style. I assume your'e using either a 82-545 or a 82-555 suction cup attached to the gun. Make sure the tubing is tight, and that the vent hole in top of the cup isn't clogged. See Binks.com for detailed tip combinations.
Jun 30, 2010 | Binks Model 7 Conventional Suction Feed...
Binks bbr converting from pressure to siphon
Worked in paint repair shop for 18+ years. Every time we had that issue it was the wrong air cap. The particular model we always had trouble with was a Devilbiss JGA going from a pressurized system to a 1 quart cup. But the Devilbiss and Binks are quite similar.
The air cap from the pressurized system would actually cause a reverse pressure in the cup.
Both air caps were for this gun. Also the Devilbiss
rep said they should be interchangeable.
They weren't. Try a different air cap.
I'm kind of curious so please let me know if this works for your Binks.
Jul 31, 2009 | Binks MACH 1 HVLP Pressure Feed Spray...
Not spraying
Sounds like you need to completly dissasemble and clean thorougly.
Feb 03, 2009 | Binks MACH 1 HVLP Pressure Feed Spray...
Binks Paint Spray Gun Repairrebuild Kit Model 18 Logo
158 people viewed this question
Top Binks Air Tools & Compressors Experts
JOHN LAPIER
Rick Amick
Rick Amick
john h
Are you a Binks Air Tool and Compressor Expert? Answer questions, earn points and help others
