Check your fuse on your power wire, should be under the hood by the battery. if the fuse is good then check to make sure you have a good ground and power on the remote turn on wire. it sounds like a blown fuse though, hope this helps. dave
Check for blown fuse under hood, trace your remote wire, inspect it for stretched, split or broken leads since this is the thinnest wire, it breaks when pulled too hard.
