Question about Kenwood KDC-222 CD Player
AM Reception I just reinstalled the Kenwood KDC 222 in a different car. The AM reception has a lot of static now, the FM is fine. I hooked up the factory radio again, that is fine on both AM and FM. Is there an adjustment on the radio itself for reception?
    Problem Solver:
  • 7 Answers
What kind of car are you driving. on some cars the antenna need to be extended in order to recieve am reception.
Posted on May 28, 2008
6ya staff
SOURCE:
AM Bandwidth
What kind of car?
Feb 07, 2014 | Kenwood Excelon KDC-X396
Fm reception for weak stations poor. reception on car radio fine.
If there is no FM Antenna connection you can try to move the power cord to different positions and see if you get a better signal. If not then move the unit closer to a window or try various locations that might have better reception.
Nov 21, 2013 | Sony ICF-CDK50 Clock Radio
Am reception dropped out suddenly on my 1999 crown vic with grid antenna
out of range or maybe stereo and mono buttons need to activate.
what could be worse is the station finally closed they're doors and retired
Aug 21, 2013 | Kenwood KDC-222 CD Player
Poor radio reception in 2008 toyota avalon
I had the same exact problem. Toyota changed the Amolifier that improved sound quality but not the FM Reception.
THE HARNESSES CONNECTING ANTENNA TO RECEIVER (TWO OF THEM) HAD IAASUES. REPACING THEM FIXD THE ISSUE. FM RECEPTION EXCELLENT NOW !!!!!!!
Apr 11, 2012 | 2008 Toyota Avalon
I have hooked up all the wires in the appropriate color-coded order and my stereo has no reception. It has power but no reception. The antenna is hooked up also. It is a Kenwood KDC 119 and the vehicle...
Selecting the station. 1 Select tuner source Press the [SRC] button. Select the "TUnE" display. 2 Select the band Press the [FM] or [AM] button. Each time the [FM] button is pressed it switches between the FM1, FM2, and FM3 bands. 3 Tune up or down band Press the [4] or [¢] button. During reception of stereo stations the "ST" indicator is ON. 1 Select the band Press the [FM] or [AM] button. 2 Select the frequency to put in the memory Press the [4] or [¢] button. 3 Put the frequency in the memory Press the [#1] - [#6] button for at least 2 seconds. The preset number display blinks 1 time. On each band, 1 station can be put in the memory on each [#1] - [#6] button.
Nov 03, 2010 | Car Audio & Video
Kenwood RV7030 audio-video stereo has static without antenna
OK I am going to suggest two aerials for you. I would also NOT use the old cable as it will cause a lot of problems. It is best to replace it with the stuff they use for satellite dishes (see image).
The FM aerial will pick up signals from all sides. The TV aerial should give high quality signals and output for at least 5 sets.
Apr 06, 2010 | Kenwood KR-V7080 Receiver
No FM reception on factory 1996 dodge grand caravan radio
replace the attenna if that does not work the radio is the problem
Jul 16, 2009 | 1995 Dodge Caravan
SL100 static and bad FM reception
I have noticed various changes in my invehicle FM reception as well. There should be a external antenna that came with your car kit. This is precisely for these types of issues. It is designed to run along the windshield inside the car closest to the Cars radio antenna. It should plugin to the bottom of the cradle. Then tune it into a clean FM station (one that has no local station on it) and position the cradle and/or ext. antenna till you get the best reception in your vehicle. It could very well be that the antenna has come has loose on your car stereo backplane. You would probably notice decreased reception on regular AM/FM stations as well though.
Your wifi reception/functionality is a completely different animal and has no bearing on the FM transmitter in the car cradle. When your on wifi your not receiving signal from a sat. anymore just simply streaming internet audio like your computer.
Good luck.
Apr 08, 2008 | Sirius STILETTO 100 MP3 Player
Bad reception
I see you've already read the "Troubleshooting" section of the manual! The only other things I can think of to check would be the actual connection between the radio (aka head unit) and the antenna. It's usually just a press-fit connection behind the radio, but if it's loose, corroded, or is touching some other metal, it could affect the reception.
There's also the small possibility something changed at the transmitter tower for the radio station. That happened in my area once, where they changed the direction in which most of the signal power was being broadcast. Westside reception got better, eastside reception got worse.
Mar 13, 2008 | Kenwood KDC-MP235 CD Player
Kenwood KDC-222 CD Player Logo
435 people viewed this question
Top Kenwood Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
