i have an compaq presario m2000 laptop and i m facing a problem with it .it freezes at bios (compaq logo screen).and when i disconnected dvd drive from laptop. it booted and worked perfectly and when i connected it, again it started to freeze. so then i disconnected hdd now the dvd drive was working as i checked it by putting a bootable disk in it.but hdd and dvd drive both together are causing laptop to freeze at bios
Thnx for answering expert
i changed bios to default configuration,will try to replace hdd or cd drive
I suggest you go to bios setup and restor the default if it continues try replacing a diff hard drive or dvd drive drive thats not the one u r using rigght now and i think the problem will be resolved cos i had a similar problem with presario c500 what i did was change the dvd drive n it work well.
hope this helps
thank u for using fixya
Hard Drive Test Failer
#1-07 Fail
