PS3 won't read discs you need to fix, clean or replace the bluray drive. Learn the step-by-step way to fix your PS3 and bluray drive is best way for you. I suggest a secret repair kit for you to fix the PS3 errors. This is an all-in-one style guide that help you to fix many cases of PS3 problems. The author is really kind and helpful to his customers. Learn the D.I.Y. way to fix PS3 issues can save you much money. You will receive much more than you spend on it. Because you can help your friends to fix their PS3 too! Please consider to buy it and share what you have learned !
PS3 Red Light and Yellow Light Fixing Guide : http://bit.ly/fixya-ps3
SOURCE: PS3 will not read game, disc or BluRays.
Prob the BluRay lens, is it still under warranty???
SOURCE: Our ps3 won"t read blue ray disc. It will read
This is a very common problem with the PS3 and is caused by a problem with the laser on the Bluray drive which is malfunctioning and can no longer read the game disk properly.
The PS3 uses a dual laser system. This consists of either a dual refractor type lens or two entirely seperate lenses depending on which pickup is fitted to your particular system. One laser is for reading ordinary DVD disks and PS2 disks and the other for Bluray and PS3 games.
The symptoms you describe are quite typical of a failure of one of these lasers i.e the Bluray laser has failed.
For more information on how to resolve the problem please have a look at this FixYa Tip on the subject.
Many thanks for using FixYa.
If you have this problem it is because the laser has shifted
from where it needs to be and the good news is that it is not that hard to fix
all you need is a good repair guide.
You can of course send it in but the disc reading issue you
should be able to fix in less than 1 hour from home.
Check out this link for a full explanation:
Hope this helps?
