HOW TO CONNECT BLUETOOTH
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
To pair
the Plantronics BackBeat 903 with an EVO 4G:
On the 903 headset:
With the headset powered off, press and hold the "Power/Pairing"
button until the LED indicator flashes blue and red. This will put the
903 headset into pairing mode.
Use the iPod Touch menu to search for the headset and select 9xxBackBeat.
(If prompted, enter 0000 for the PIN code/passkey. Some devices also
require you to accept the connection. Headset is paired when LED flashes
blue.)
On the EVO 4G:
Turn
the Bluetooth on from the Home screen, tap Menu, Settings, Wireless & Networks,
Bluetooth.
Pair
the EVO 4G by going to the Home screen, press Menu, Settings, Wireless &
Networks, Bluetooth Settings, Scan for Devices.
Follow the on screen prompts to pair the devices.
Good luck from Headsets Direct - 800-914-7996.
My daughter bought new Htc phone. Gave me her old one. Not a geek.Need to know so much. I do not use this device as a cell phone.
