Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
Anonymous Posted on Oct 02, 2010
How do i set a 'spin only programme on my hotpoint ultima extra washing machine
  • Anonymous Oct 02, 2010
    thanks heaps
Ginko
Level 3:
  • Hotpoint Master 19,396 Answers
  • Posted on Oct 02, 2010
Ginko
Hotpoint Master
Level 3:
Answers
19396
Questions
25
Helped
8076737
Points
55462
Hi.
This machine does not allow setting spin without using drying programme or without being in a full cycle.
You can use the cycle G pressing the button 6, 7 and 8 times, please see page 12 in the manual below.
Instead of the spin only program you can als use the independent dry program, as shown at page 11 and 15 of the manual.
Manual available here.
If you repute this solution helpful, then please do not forget to accept the solution.
Many thanks.
Ginko.
  • Ginko
    Ginko Oct 02, 2010
    Hi.
    Thanks for the feedback.
    Have a good day.
    Ginko.
Hotpoint ultima washing machine wma74 drum not turning
If the machine wasn't excessively noisy before and when you select spin only you can't hear the motor running its likely to be the carbon brushes in the motor worn down till they no longer contact stick a new set in if the carbon length sticking out the brass holder is less than around half an inch long
1helpful
F-04 on hotpoint ultima can you tell what this means please
"F04" on the display panel before the programme ends. Have you cleaned the filter out on the pump
6helpful
3answers
My Hotpoint Ultima WMD 960 displays "F04" on the display panel before the programme ends. Have cleaned the filter and it worked OK in spin mode and finished normally but now have put in a washing load, it...
Error code F04 means pressure switch jammed on empty.
Do the following.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside the hose.
Remove the hose on to the pump, and check for blockage or obstruction here as well.
Please rate my solution.
Thankyou.
F8 flashing as about to spin on every programme
F08 is a heater fault so although you may feel the machine has washed it probably has'nt.Check the heater, pressure switch and module for lose or brocken wires.
2helpful
Will not spin.
could be a couple of causes.First take off panel at back of machine and check that belt is in place.
Has it been noisy on spin lately?
WASHING MACHINE
Turn machine off and unplug for at least ten seconds
Then plug in and retry - according to Hotpoint that should solve problem
"Test" displays no washing done!
Your test mode is on, maybe accidently. Press "start", "cancel", "on" & "off" together for 10 secs, you will see d/off come on the display. Do the same & the test mode comes on again.
Rate pl.
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
