My front load Duet washer gave me the F22 code. I cleared that by canceling the cycle, checking the door and restarting. Now, it will not lock the door and run. When I hit the "start" button, it just beeps three times. I've tried unplugging for a few minutes but still get the same result. Can you help me?
Does your front washer, every time you press cancel give you a code that looks similiar to ER?
I checked the description and for some reason whirlpool denies having a F22 code on the Duet, but that doesn't mean much.
I am suspecting several things.
1. Electrical supply may have had a surge at one point or another. You may have to ask your electrical company to put a surge protector on your house by the meter. This is not to protect everything it has its own limits!
2. Unplug the machine for a while. Turn off the water supply and disconnect hoses The machine knows if there is water coming into the machine by a trip sensor.
3. drain out your exhaust line. There is a possiblity your machine thinks you are full of water when it is actually empty.
4 put everything back on, and then plug machine back in after about an hour or so. If it still doesn't work, it is time for your local appliance repair service technician to come out. He will check door trip sensor, and a few other areas that may be acting up.
Good luck.
Five week old WFW9200SQ Duet washer suddenly showed F22 code after a load finished. Could not open the door. Ran the load again and got the door opened at completion. Then added a new load and the start button just beeps when I try to start the load. Will not run.
