The grills behind the bulb are distorted from overheating.i moved itfarther from the wall,i can barely detect any air movement coming from inside.
its a year &1/2 old and gets plenty of use.we live in phoenix,so in summer it's usually 75 degrees inside the house.i thought about mounting a small box fan about the size of opening to help pull air out of unit,seems to be a problem with air flow? what do you think?
originally i thought the bulb needed replaced.but after letting it cool down(power off),it would be ok for a while.got to where people turned green & gray after 10 minutes.i took the back cover off &vacuumed all dust,3 fans run,1in front of bulb,main one in center &1behind circuits.put it back together & works maybe 2 hours before people turn green.i think it has a ventilation problem.can you help me ?thanks in advance
[email protected]
