Bought new card.
when inserted in camera states
card not initialized
I have a Fuji Fine pix A120 and I inserted a xd-picture card M1GB, and all I get is cardnot in
I have a M XD card and i can't get the camera to upgrade so that i can use my new card did I waste my money?I have a M XD card and i can't get the camera to upgrade so that i can use my new card did I waste my money?
You can't post conmments that contain an email address.
You will need to do a firmware update to be able to use your new 'M' XD card. Also you will need a AC adapter to be able to use the update for your camera.
It is a Fuji site and it works.
Good luck. http://www.fujifilm.ca/x3719.xml
the camera cannot use XD picture card and multimedia card (MMC). SD and SDHC can be used. for compatibility check this http://www.fujifilm.com/products/digital_cameras/accessories/card/a/
you might need to update your product depending on your serial no.
to format the card, press menu to display menu setup, press right to move to setup 2 (3rd tab) you will see Format. click Format to format the memory ("SD" is displayed if memory card is inserted and "IN" (internal memory) if no memory card. hope this helps
Olympus cards don't always work in Fuji cameras. Maybe not at all in older Fuji's.
You could try and update the firm ware in your camera and see if that does anything (if it's available on the Fuji website) Go to the service and support section on the web site and you may be lucky
If your new xD card has an "H" or an "M" before the 1gb, it is not compatible with your camera unless a firmware upgrade is performed (go to www.fujifilm.ca and follow the links for support to the firmware upgrade section). If the card doesn't have the H or M, you just need to format the card in the "set-up" menu of the camera.
Hi I have bought a new memory card, Olympus XD M 1GB. For my Fuji fine
pix A330 camera, and I can't get it to initialise, or format properly,
can you help me many thanks TRENA
Try this site for a firmware update. You need to get a AC power adapter for it to work though. It is from Fuji and it worked fine for my A120. The older XD cards are of a different format then the newer ones so if your new XD card has an 'M' on it you will need to do the firmware solution.
Good luck http://www.fujifilm.ca/x3719.xml
This could possibly be a problem with the card reader ..Just insert a different card and see if it works..If it reads other cards..then i advice that you get new card coz the recovery softwares and stuff r pretty expensive and will be a waste of money..
You have to go to the menu/setup function. Check the different settings. One of them would lead you to the memory card settings, from there you should be able to format the new card.
Good luck and kind regards.
