SOURCE: mercedes a class gearbox fault.no gears
If you take it to mercedes they will charge £3500 and will replace the gearbox, Alternatively you can change the shifter valve £25, new sump and filter as they have changed, fit a magnet inside the gearbox as the early A didnt have one. Fresh oil and see how you get on, the control unit for the gearbox sits inside the gearbox £1000 roughly for a new one but it has to come from mercedes in germany where it is coded to your chassis number, 2nd control units are not an option!!!!!!!
jib
www.mercanic.co.uk
SOURCE: My car will not Shift gears; Its stuck in first gear
hi,it seem your car is in emergency mode,you can check oil lever if deep stick is present,if not, better to bring your car to your dealer for proper diagnose,maybe erase fault only,ty
SOURCE: switch to 4 wheel drive in Mercedes Benz GL450
You have permanent all wheel drive dude. The system is always ready to go. If you want to do some offroading, activate the "off road" button that looks like a vehicle climbing uphill on the lower, center dash panel. This will allow more slip for the traction control system and hold lower gears longer in the trans
SOURCE: I have A class mercedes Benz ASB,ESP light came on
It is OK to drive it I recommend you fix it when you can It is most likely the stop lamp switch located on the back of the brake pedal part is 25-35 dollars depending on where you live have it tested before replacing. If it tests good you have a faulty brake sensor in one of your wheels check brakes
