Sony Trinitron 36" keeps blinking the standby light (7 blinks in each interval) but will not turn on. No Picture No Sound. Can you please give me some information on how to fix this problem ????Sony Trinitron 36" keeps blinking the standby light (7 blinks in each interval) but will not turn on. No Picture No Sound. Can you please give me some information on how to fix this problem ????
Standby lite is just blinking... will turn on but no picture and no sound... Standby lite is just blinking... will turn on but no picture and no sound...
Our Sony KV 34HS420 is having a standby problem. We have never used the sleep/standby option. But lately, if you turn the TV off then decide to turn it back on it will go into standby/sleep mode. Then it's hours before you can get it to turn back on. I cannot find my manual. I've been thru the TV menu to see if there's something I can do there, but no luck. Help!Our Sony KV 34HS420 is having a standby problem. We have never used the sleep/standby option. But lately, if you turn the TV off then decide to turn it back on it will go into standby/sleep mode. Then it's hours before you can get it to turn back on. I cannot find my manual. I've been thru the TV menu to see if there's something I can do there, but no luck. Help!
I have an older Sony Trinitron. Its big and bulky and heavy compared to the recent models. But it has great picture and sound when it works. I got it repaired once for the same problem. Turns on and goes to standby. Paid a bundle. I see one fuse and the TV clicks loudly right in that area. So I'm hoping its the fuse. It blinks 38 or 39 times on standby before the red light goes off. I try to turn it back on by hitting the power button not once (because it does nothing) but on the second try it starts to do the same thing and nothing happens. Any suggestions? I'm going to Radio Shack to see if I can find the fuse. It looks caked in white. By the way when I opened the back of the TV it is just filthy. Do I need to get it cleaned ( perhaps this is causing it to overheat). Just asking. I know I should by a new tv. Its at least 15 years old. But don't have the money right now. Thanks.
I have a 2002 Sony Model # KV-32HS500 and the stand by light keeps blinking 7 times, pauses and repeats. I have a 2002 Sony Model # KV-32HS500 and the stand by light keeps blinking 7 times, pauses and repeats.
my standby light blink 6 or seven times . i get sound for about 2 seconds then it shuts offmy standby light blink 6 or seven times . i get sound for about 2 seconds then it shuts off
It sounds that there is a direct short circuit in anywhere in circuit board. Most probably, it might be to vertical sweep output section, in Sony TVs. Here you noted that the standby light blinks. Blinking of standby light to Sony TVs are fault indications. Count it, and check this.
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Sony Trinitron TV. Worked well last evening. Now picture won't go on. When power is turned on, standby/timer red light flashes, but picture or sound does not work.
Does the ligh blink a certain number of times and the stop briefly and repeat the same pattern? If so you have a problem that is beyond your ability to service it and must be serviced by a certified sony tech.
If you are not a professional Electronics guy,it is beyond you to tackle this problem. otherwise log on to www.free service manuals.com and see the SONY Blink codes and also download the service manual.best of luck
no picture. th tv is in stanby mode and i get 4 blinks of red
My stand by light blinks 7x no sound or picture
My tv has same problem but flashes 10-11 times in standby mode
i just got it from a buddy an the standby light just flashes
WEGA TRINITRON KV36FS200
@ 12-14 blinks upon plug in/ then cycles of 5 blinks - won't turn on at all
Same as above. I can not turn on the TV
i have a sony kv32hs500 and it blinks 7 times
red light blinking 7 times, using remote power turns on then off
