417 44152400 21 code reads e63 and machine not draining properly
Good Day,
Your
washing machine is fully automatic?
the
washing cycle is normal?
if yes
do the same maybe it will help you.
for
the fully automatic washing machine mostly have drain pump, please check the
filter of your drain pump, how? remove the cup of your drain pump like a
ordinary cup, screw it clock wise or counter clock wise.
Remove
drain pump filter and clean it, some hair pins, cotton buds or coins or any
small item that coz of clog up.
if
your washing machine dont have drain pump ,but fully automatic check the drain
motor if running or not? how? open the back cover for top loader washing
machine only, select spin cycle and press start to see the drain motor running?
the drain motor is like a small box with small wire to pull the lever of the
drain to remove water inside, if the motor running or pull the lever of the
water pipe but water still inside the washing machine, remove the drain cup or
cover and clean it or check if have coin or cloth inside that coz of clog or
water stuck,
if the
drain pump or drain motor is weak this is will cause and long time draining or
totally not running the drain pump or drain motor and its cause of totally stop
the cycle of washing machine in rinse time or spin time, because all fully
automatic washing machine, after washing cycle the drain pump or drain motor
must be on, to remove water before start the next cycle. rinse or spin cycle.
check in the manual for the error code most of washing machine
if the error code is in users manual its means its only minor problem,but if
the error code is not in users manual its means you need to call an service
technician to not waste your money or time if you do by your self.
