Question about Dell Inspiron 6000 Notebook
Blinking Lights, Computer Wont Boot
I have a Dell Inspiron 6000, almost three years old. I press the power button on the computer (and have tried holding it down for ten seconds or more as well), and all of the lights blink green once, then the "A" light blinks nine times, then nothing. Nothing else happens, no whirring sounds, nothing. I replaced the battery with a new battery, and it worked once, but the next time I tried to turn it on it did the exact same thing as before. Any ideas what it might be and/or what to do? Thanks!
  • khoward459 Oct 21, 2008
    I have a dell inspiron 6000, three y old. I knew the battery was on its way out, only holds a 20 minute charge, but now the power light blinks, 4x amber and 1 green repeatedly, regardless if the laptop is plugged in with the computer off or on. What does this mean?
  • Wallace Hardin
    Wallace Hardin Dec 21, 2008
    I press down the power button lights go on for a few seconds and it shuts down, no whirring.Have tried holding button down for ten seconds...it just shuts down
    Scholar:
  • 187 Answers
If it's blinking 9 times then it's likely telling you one or more of the RAM sticks are in need of replacement. To check these, remove the laptops power cord and battery, then locate and remove, the cover for the RAM. Remove one chip at a time and try booting the laptop.
Posted on May 25, 2008
6ya staff
SOURCE:
Apple Computer will not turn on
Try holding down the power button for ten seconds, the press at the same time, the left shift, option, an control buttons at the same time. Hold for ten seconds an release the three but continue to hold power button for ten more seconds. Its a reset.
Mar 27, 2014 | Vehicle Parts & Accessories
My Dell Inspiron 1525 is stuck in "hybernation." It will not let me "control, alt, delete" and I've even tried removing and reinstalling the battery. Help! Thank you!
Press and hold down the power button until the computer shuts off. Then wait at least ten seconds and power it back on.
While it is booting up and you see the Dell logo on the screen, press and hold the F8 button. When the next screen appears, you will see a list of options for how you would like to continue the boot up process. Highlight the option titled "last known good configuration" and press enter. Your computer will restart and load up with all of the settings previously used before it began giving you problems.
Apr 23, 2011 | Dell Inspiron 1525 Notebook
I need to restart my dell inspiron 6000 how do start it over
hold the power button till it turns off ten wait 5 seconds then hit the power button again
Nov 07, 2009 | Dell Inspiron 6000 Notebook
My screen on my dell inspiron 1520 has gone black
You've lost your desktop display.
The first thing I would do is to start the computer in safe mode. Once there, do a system restore back to the time that it worked.
I would also, just to be safe, do your disk management tasks like checking your hard drive for errors and running defrag.
Oct 22, 2009 | Dell Inspiron 6000 Notebook
My computer will not load up
Likely a hard drive failure. With system off, hold the Fn Key and press the power button, this should launch diagnostics If the diags fail on the hard drive then you have a confirmed failure. If the diags don't run, then try booting to the resource CD to run them.
Oct 12, 2009 | Dell Inspiron 6000 Notebook
Dell inspiron 6000
On ac power when you hit the power button, if there are no lights, it could be the power supply. If there are lights, try starting it without the battery, ac only. If there are lights and it still doesn't start after removing the battery, try a different memory chip. On Dell machines the battery can acquire a dead short causing it to not start. Also if the memory chip/chips have gone out it will cause it not to start. If it still will not start after these three it's a motherboard problem and will most likely have to be replaced.
Jun 15, 2008 | Dell Inspiron 6000 Notebook
Problems with Dell Inspiron 6000 Battery ? DELL Inspiron 6000 laptop battery is popular, why ?
You can also pick up the batteries less expensive than most computer places at batteries plus. And yes it sounds as though it is the batteries charge is getting low, especially if it runs fine when the battery is out and you have it plugged in.
Mar 13, 2008 | Dell Inspiron 6000 Notebook
No power
This might work. Unplug the power cord connected to the back of the PC. Press & hold the start button on the PC case for ten seconds. Reconnect the power cord & try starting the PC. Still no power. Connect the power cord from the PC directly to a wall jack. (No power strips). Still no power? Possible the power supply went bad.
Jan 07, 2008 | Dell Inspiron 3800 Celeron 500MHZ...
Inspiron 4000 problems
First, can it boot into BIOS setup? This is DEL, Esc, F1, F2, or whatever key your user manual instructs; press the requisite key immediately after pressing the power switch. Second, can it boot from an emergency recovery disk from the floppy, or a boot CD from the CD drive?
Mar 12, 2006 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Notebook Logo
537 people viewed this question
Ekse
Clive
Clive
Alun Cox
