#1 Wait until you are out of ink. The warning light and ink-low notifications come on well before the ink cartridge is empty, and even if it runs out of ink in the middle of a print, you can replace it then and finish the print with no problem.
#2 Lift the lid of your Epson inkjet printer to expose the ink cartridge replacement button. Make sure you have plenty of light so you can see what you are doing.
#3 Press the ink cartridge replacement button. This will loosen the empty ink cartridges so they can be pulled up and out.
#4 Fill the empty cartridge at an ink-refilling location, or buy a new ink cartridge to replace the empty one.
#5 Insert the new or refilled ink cartridge into the holder with the same orientation as the previous one.
#6 Press the cartridge replacement button to charge the system and close the printer cover. Charging takes about one minute
Thanks
SOURCE: how do i change the
press: INDEX SHEET and SCAN both at the same time, use two fingers if possible.
Your epson monitor Screen should show: NOZZLE CHECK and below that a left and right arrow with 1/6 between them. using the right hand arrow key just below the monitor, scroll through to item 4. then press the green start key to get the carriage ink holder to move into change position.proceed .
SOURCE: how do i change my ink cartridge on the epson
Click on the start menu then go to Printer and Faxes. After that go to your default printer Epson SX215 and right click the printer then click properties. Dialogue box was appear click on the maintenance and then click replace cartridge their was a dialogue box will also appear. Just click the next button and read the instruction when you press the Next button. After that open the cover of your printer when the cartridge are at the center that's the time you can change the cartridge. Then close the cover when you're finished to change the cartridge. Then click the next button and so on to finish.
SOURCE: Epson Stylus SX215 the ink cartridge holder won't
its because the ink housing will only aline when the ink is empty its not like any other printer that you can line the housing up. Wait until you run out of ink then lift up the lid and the housing will be alined - its stupid system and epson dont tell you this when you buy the produc
SOURCE: How do I change the ink cartridges on an EPSON
Hi joanmcd2, Just go to control panel and go to (printers for xp)/(device and printers win 7)
open the properties of the driver and goto Maintenance tab and then click the EPSON Status Monitor button, you will see the ink levels and there will be an option to replace the ink.
for details pls dwonload the Sx215 manual on this link
