Question about Toshiba Satellite A105 Notebook
My Toshiba Laptop
When I turn it on, it takes like 20 minutes for the icons to show up, then I can't go on the internet, I get an error everytime I try to open my files, or pictures or anything. I have de-fragged about 7 times but nothing is working.HELP
  • 50 Answers
Specify the error message or code. Suspect the computer is busy with system restore and visited webpages updates when you switch it on. When you turn off computer, allow it to close/exit/end all programs and processes. Disable automatic updates, optimse computer by dumping needless history, temp internet files, cookies etc.
Posted on May 25, 2008
  • 42 Answers
Click Start>>Run>> (type)Msconfig>>Click ok
System configuration utility window will open up
U will see few tabs at the top like General,Startup
Click on startup tab
At the bottom click disable all>>Close>>It will ask for restart
Restart the computer
when the computer restarts you will get the message
You have used the system configuration utility
Check the box at the bottom Do not Show this Message Again and click ok
Now you wont see the icons that use to load up on the right bottom of your system,however they have not been deleted just hidden,if you want to access any of those programmes that use to appear before
Click start>>All Programmes>>and clik the application you need to open.
6ya staff
SOURCE:
How to fix TBX Error on Toshiba Satellite a205-s4707
Take out battery from it, and re-insert it after 15 minutes or so. This must make it a hard reset. If it too doesn't help you, make sure there is a software corruption has been occurred. Re-install the O/S is the only solution. Electro help
Jun 06, 2014 | Toshiba Satellite A205-S4707
Laptop is very slow, hangs when opening muliple applications. It takes 20 -30 minutes sometimes, to even respond to a single click done
yes it showing the downloads for the points of interest onthe satnav
but iit is not showing the b m p icons as to where they are
regards bob
Jan 26, 2014 | Computers & Internet
My laptop is connected to the internet but everytime i try to go online it gives an error message of: the internet explorer has stopped working,window is checking to see if it can solve it. whats wrong...
How are you connected to the internet? Sometimes when you're connected to the internet via wifi, the icon can show that you have a strong signal and that you're connected when you actually aren't. Optimum wifi does this often. Turn off your wifi, wait 30 seconds, then turn it back on.
Dec 07, 2010 | HP Pavilion G60-235DX notebook
How to troubleshoot my advent4211c for it to connect to a wireless internet network
First turn wifi on using functions keys (I think Fn+F11). A little icon will show at the bottom right task bar which will have a picture of a pc monitor with a red X symbol. Right click on this and select View available wireless neworks. Once you have that, you will see what you can connect to and simply connect. Please remember that you will always have to turn wireless on using the function key everytime you start your laptop again because for power saving it switches it off everytime you turn your laptop off
Jul 11, 2010 | Advent 4211c Notebook
Laptop Toshiba A60 - Heats Up, goes off after running 20 minute
replace the battery . battery has its own life time and after that it needs to be replaced . so do it.
May 13, 2010 | Toshiba Satellite A60-S1561 Notebook
How can i resolve DNS error? everytime we log on to internet explorer it says "servor could not be found or DNS error". we're on windows XP. thanks
how are you connecting to the internet? Cable/DSL or dial-up? If cable/DSL do you have a router?
shutdown the laptop, Reset the modem(power off wait 30 seconds, power on), reboot the laptop and try again
May 13, 2009 | Toshiba Satellite P105-S6177 Notebook
Cannot access any programs on Toshiba Satellite A135-S4517
Either a tune up, or it has a faulty hard drive. If you can manage to get to My Computer, right click your C: drive, select Properties, go to the Tools tab and click Check For Errors. Check all the options, and start it. It will tell you that the tests can only proceed when you reboot. Check it in order to do so and reboot.
Good luck.
Oct 28, 2008 | Toshiba Satellite A135 Notebook
Toshiba satellite A135-s2246 laptop not turning on
u need to reset your bios settings.
Open your laptop back case then put the cmos cell for 20 minutes.
Oct 25, 2008 | Toshiba Computers & Internet
Wireless Internet Access
Hi, Normally there should be an Icon at the system tray (lower right) which is for the WiFi. Placing your mouse over the icons would tell you what the icon is for. Right clicking on the WiFi icon would show you whether it is enable or disabled. Double clicking on it would give you the WiFi access window where you can select which WiFi network you can connect to. Some of these wireless internet cafe would grant free access while others would need you to check-in with their admin or somebody and on certain cafes for a fee. Hope this be of some help to you and pls post again how things turn up. Kind regards.
Jul 19, 2007 | Toshiba P205-S6267 Notebook
Toshiba Satellite A105 Notebook Logo
151 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
