Question about Krups FBC2 1600 Watts Toaster Oven with Convection Cooking
ELECTRONICS SEEM TO WORK (ON/OFF; TIMER; CLOCK; OPERATION SELECTIONS [TOAST, BAKE, ETC]) BUT ELEMENTS DO NOT LIGHT UP
    New Friend:
  • 50 Answers
Check the resistance of the plug by turning the timer and temperature switch, if there's no resistance, open your unit and check the resistance of thermal fuse which is connected to line wire. it is look like resistor..if the thermal fuse is ok then check the resistance of heating element..
Posted on Sep 30, 2010
6ya staff
SOURCE:
The toaster oven does not toast. the oven and timer work, though
Your selector switch may be broken if the oven works on selections other than toast.
Jan 05, 2010 | Black & Decker TRO390 1200 Watts Toaster...
Labels on black and decker toaster oven worn off CT0650C
Top dial is Bake/Broil knob, it goes left to right. Starts with OFF @ 9 0-clock next is 100 dgre then @12 o-clock 180 Deg. is at top center next is 250 Deg. next 350 located opposite of off. Next @ 4 o-clock is 400 Deg. Next @ 5 o-clock is 450 Deg. and finally at the bottom at the 6 o-clock position is BROIL. The Center Knob is BAKE TIMER . Starts @ off position as 0, next @ 10 o-clock is 10-mins. Next @ 12 o-clock position is 20 mins. Next @ 2 o-clock pos. is 30 mins. Next @ 3 o-clock pos. is 40 mins. Next @ 5 o-clock pos. is 50 mins. Next and finial pos. is 60 mins. The Bottom knob is TOAST @ the 9 o-clock is is 0 next @ 11 o-clock pos. is Light , Next between the 12 & 1 o-clock pos. is MEDIUM and the final pos. @ 3 o-clock is DARK. TOAST.
Jun 13, 2009 | Black & Decker CTO650 1500 Watts Toaster...
Burnt pie
YES YOU ARE your trying to bake something in a toaster oven :) toaster ovens have two modes toast /bake in this mode top and bottom elements get hot .and broil in this mode only the top elements get hot . the problem is the marketing the word OVEN makes you think of a normal oven that the bottom elements do all the work . toaster ovens work well melting stuff and toasting . thats about it . if you must bake in it try placeing a sheet of foil on top of your baked goods it might insulate the top of you food . good luck ... if this answer helped please rate it a 3 or 4 stars , this high rateing will help keep me in the paid answer department , thank you
Apr 13, 2009 | Toaster Ovens
B&D TRO200 Toast-R-Oven bake function does not work
its not repairable at any price . you have a bad thermostat , its soooooo common with this oven . asprie who makes this oven in china, then inports it with black & deckers name on it . has not made any parts for it , not even a wire shelf or a knob .....when something happens to it , you toss it in the trash .....
Mar 07, 2009 | Black & Decker TRO201 1550 Watts Toaster...
I bought a kenmore toaster oven. There were no instructions.
This controls the heating elements in the oven Briol// Bake// and Toast
Dec 16, 2008 | Toaster Ovens
Oven does not turn on
These ovens have a timer switch that lasts just about a year. Mine did the same thing and you cannot find the timer switch anywhere in the USA. The switch is likely a DKJ/1-60. There is a switch made by Delonghi that will work. The part # is 05XDE5218104600. You can get one at "The Gourmet Depot" website for $10 + shipping.
Jan 23, 2008 | Black & Decker CTO6300 Toaster Oven with...
Cuisinart toaster oven modele no.TOB-30BWC, serial no.50421.
The contacts for these toasters fail. The plasic cam that depresses the contacts also can melt. The design is poor and no replacement parts are available. When selecting a setting, if the selection is not exactly perfect, the contacts arc and eventually fail. Unless cuisinart changes the selection cam to a solid state or relay, this failure will continue to happen during normal use. If your unit works properly do not switch the function setting while heating, this will cause the contacts to arc and erode the contact surface. This posting is applicable to the TOB-30BC, TOB-30BCC and probably all TOB-30XXX models.
Dec 26, 2007 | Cuisinart TOB-30 Toaster Oven with...
Krups FBC2 1600 Watts Toaster Oven with Convection Cooking Logo
328 people viewed this question
Top Krups Toaster Ovens Experts
Thomas F. Schneider
Marvin
Marvin
Are you a Krups Toaster Oven Expert? Answer questions, earn points and help others
