Hi Shellinator7.
check the small drain hose on the side of the pump that is clogged, then that is not a failure that will significantly affect the normal operation of the washer. If your washer is not draining okay and you don't mind catching some water that spills out of that pump filter area when you open it up, then you don't necessarily need to remove that front panel and bother with unclogging that small drain hose. If the large hose between the tub and the pump or the discharge hose between the pump and the house drain behind the washer is clogged, then you may need to open up that cabinet.
you could also check out this link and read up some more on this.
LG Tromm front load washer not draining in the spin cycle Google Search
SOURCE: spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the
second to last rinse cycle and that most all rinse cycles are in cold
water. Is your cold water valve screen plugged causing your washer to
rinse poorly? Are you using the HE detergent? If not maybe the
washer is sudsing up to much and having a hard time rinsing all the
suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting
does it take a long time to fill the washer up? Also when it is full
and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of
the washer it might have a hard time draining out all of the soap
water before the next load
SOURCE: LG Intello 7KG Washing Machine
You may have some articles that made their way into the pump housing. Alot of times I see dimes get stuck in the ports of the pump, remove and check out thoroly and also check hoses coming to pump for little son of a gun articles that like to hide.
SOURCE: lg wm1814cw model front load,
What you can do is go into the test mode, and see if the drain pump is operating, if not you will need a need drain pump. Do not put it into spin in test mode if you have clothes in there
Sgt 48
SOURCE: My LG TROMM (WM1812CW) does
This code means that something is blocking either the water drain pipe,
pump filter or the pump itself. I had the same problem and removing the
filter (as recommended by LG) did not help. It turned out I had a piece
of debris stuck in the pump propeller itself and consequently the water
would not drain and the wash would not finish, prompting the error.
This is what I did to fix the problem.
1. I removed the cover on the left bottom corner and the removed the filter and unhooked the little rubber tube (drain).
2. I removed the pump cover (lower left corner of the washing machine) and unscrewed 3 screws holding the pump from the front.
3. I disconnected the power supply and removed the back panel (attached with 4 screws)
4. Disconnected the two hoses (one black, one gray) from the pump.
5. Disconnected the power supply to the pump (I had to cut a plastic
tie holding the connector in place in order to bring the connector
closer so I can disconnect it).
6. Removed the pump by pressing a little tab that was holding it from the back.
7. Once I removed the pump from the washing machine, I took three
screws out of the pump motor, gaining access to the propeller. This is
where I found a little piece of plastic. Apparently propeller couldn't
spin because of that obstruction.
8. I put the pump back together and attached the hoses. This is easier
to do when you have the pump closer to the back opening of the washing
machine.
9. I then connected the pump power supply connector, locked the pump back in its place and replaced the screws.
The total repair took less than 45 minutes. The hardest part was to
remove and replace the drain tube springs, because I did not have the
right pliers (You need decent size pliers or plenty of strength in your
hands to squeeze the metal bands).
The tools you need for this repair are:
a philips and flat screwdrivers, large pliers and a sharp knife (to cut a plastic tie)
SOURCE: Drain pump on LG Washer
Have the same problem , but when it gets to the drain cycle ( about 12 min left ) will chime and show an i con on display ( washer with a hose on bottom left with an X on it ) and it doesnt drain. I un plug and let sit for awhile , turn on and go to no spin and it will manually drain ( sometimes ) Do I need and New drain pump?
