Rear projection tv has sound but no picture for the first hour
Inlaws rear projection tv has sound but no picture for the first hour or so then the picture comes on. what is the problem and how can i fix it SOME PLEASE HELP
Re: rear projection tv has sound but no picture for the...
Hello
The problem is most likely the the video processor module
bad (surface mount caps.) app. 8 to 10 of them.
If you are good you can replace them.
if not replace the module.
guy9
Sounds like your convergence modules have gone bad. They have 21 close spaced pins to unsolder and resolder. You'll need a soldering iron with a fine point tip and thin gauge solder to do the repairs yourself. Solder bridges between pins are common when soldering these module pins, so have some unsoldering wick handy if you're going to fix it yourself. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
I had the exact same problem. The screen would shrink then expand. After thrity minutes it would correct itself. Then one day it just broke - no sound and no video. I searched these forums but did not find clear instructions on how to fix it. I gave up and called in a repair tech. He fixed my TV in less than 30 minutes. To help others like me I documented the fix and created a step by quide and repair kit to fix the problem. You can find it here. http://www.magnavoxhelp.com
NO PICTURE BUT I HAVE SOUND MODEL 53FDX01BA
