I have one desktop with a wired connection to the router and one laptop with a Belkin wireless network card. I am able to access the internet no problem on both machines. I am also able to access each other computer through my network and printer share, etc.. The problem I have is that once I make a connection to the other computer say from the laptop to a file on the desktop that connection is not consistent. I frequently have problems saving a file I have open (small word files, etc.) and I usually have to keep connecting through clicking on the network path in explorer which becomes a PITA. Also, I often experience spotty connection with iTunes while sharing my library. These problems seem to be linked.
Any thoughts?
TIA for the help
Aaron in SC
SOURCE: WEP Encryption
It is recommended to enable encryption on your wireless router before your wireless network adapters. Please establish wireless connectivity before enabling encryption. Note: Your network will slow down and wireless signal may degrade when enabling encryption due to the added overhead. Step 1 Log into the web configuration of the router by opening up a web browser and typing in the IP address of the router (192.168.0.1). Step 2 Enter your username (admin) and your password (blank by default). Click OK . Click the Home tab and click the Wireless button on the left hand side of the screen. Step 3 Select Enable next to the WEP radio buttons. For WEP encryption select 64, 128, or 256-bit encryption. For the Key type select HEX. If you have an option for Authentication type, select Shared Key. Step 4 Select Key 1. Enter a Hex encryption key that you make up. The length of the encryption key will depend on what you selected under WEP Encryption. 64-bit encryption 10 characters 128-bit encryption 26 characters 256-bit encryption 58 characters (available on DI-614+ only) The encryption key is HEX, meaning 0-9 and A-F are valid characters. For example, A4583DFF1A (64-bit HEX key). Step 5 Click on the Apply button then click on the Continue button to save your settings. Note: If using non-D-Link adapters, please refer to the manufacturer´s documentation on enabling encryption.
SOURCE: enable WPA-PSK
Step 1 Log into the web-based configuration by opening up a web browser and typing in the IP address of the router (192.168.0.1). Step 2 The default username is admin (all lower case) and the password is blank (nothing). Click OK. Step 3 Click on the Home tab and then click Wireless on the left hand side. Step 4 Select WPA-PSK using the radio buttons. Step 5 Enter a key (passphrase). The key is an alpha-numeric password between 8 and 63 characters long. The password can include symbols (!?*&_) and spaces. Make sure you enter this key exactly the same on all other wireless clients. Step 6 Click on the Apply button then click on the Continue button to save your settings. Note: If you are configuring your router from a wireless adapter, you will lose connectivity as soon as you click Apply. You must enable WPA-PSK on your adapter and enter the same exact passphrase as you entered on your router.
SOURCE: D-Link DI-624 wireless router is not working after firmware upgrade try
Try to unplug the router and hold in reset button for 30 seconds see if that works, you probably did that already, But if you can get your computer to respond you should be able to open software Bios. and do your firmware update from there. If not I believe a hard reset is with the router plugged in and holding reset button for 30 seconds, I don't know I sure hope that resets it for you. Thanks take care
SOURCE: Internet via another computer's DSL
Ok so your computer says conencted to wireless network,
Check if the pc is getting a valid ip address follow this Click start>RUN>type CMD>click OK>then type ipconfig you should be getting a 192..x.x.x if you're getting a 169.x.x.x ir means that you're really not connected to your wireless network, if there's a wireless security enable on your network make sure you have the correct key.
I figured it out myself. Change the setting for the preamble type. Advanced_Performance_Preamble type:
Select "Long Preamble"
I don't know how I figured this out. Just got lucky!
Pretty cool, now I can control my iTunes music in the house through remote desktop via the laptop without any connection problems!
