SOURCE: Won't boot
was there any changes done to your system like upgrading anything
All your power seems to be on right
SOURCE: Laptop fails to boot up. Caps lock & Num lock
The problem may be your display LCD is not working - check that hard disk is running - when you touch you may feel a running sensation -
There are many problems It can be motherboard problem or any of the devices is not working ie.. hard disk PCMCIA Cards i suggest you should an expertize check.................
SOURCE: cannot power on only led light
Welcome to fixya, This could be a number of issues.
It could be your ram chips need to be replaced, it could be your battery.
Try this to narrow it down.
Remove the power cord, and the battery.
Press and hold the power button for 30 seconds solid.
Then, do not put the battery back in, just the power cord.
Try to start the computer, if it starts, your battery is failing.
If it does not start, leave the battery out, remove the power cord.
Turn the laptop upside down and remove and reinsert the ram chips.
Then, plug the power cord back in and try and start it again.
If it starts, your ram chips may be failing and you should think about replacing them.
KittyTech..
If you need further help, reach me via phone at https://www.6ya.com/expert/carolyn_427ff26936286336
SOURCE: Dell Vostro 1510 laptop.NUM lock
Go to dell site and check what LED flashing means.This points to the problem.good luck
