Question about Grohe Satin Nickel Soap Dispenser...
My Grohe soap dispenser leaks under the sink. The bottle simply hangs off the pump. It looks like it should screw on the dispenser but there was no nut. Is this correct?
    Scholar:
  • 81 Answers
Virtually all soap/lotion bottles have threads on the top of the bottle and are designed for initial installation only since all if them are refillable by pulling up on the pump head. Grab the bottle and twist to the right. If it will not tighten then the threads are stripped out and complet dispenser replacement is required. Grohe does not sell either the pump assembly nor the bottle separately.
Posted on Sep 29, 2010
  • 2 more comments
  • junky22 Jan 01, 2011
    We just remodeled, so my Grohe soap pump in less than a year old. I have the same leak. So this thing should be tightening up? I thought so, but came online to find the manual, which I haven't found yet. Mine is just spinning around too. It is still in warranty, so should I request a replacement? Also, I can't get it off either? It just spins around both directions. Any ideas?
    Thanks
  • mysonjonas Feb 22, 2011
    Your wrong (Guru).The Grohe has a double sided nut with different thread sizes to catch the black thread on the dispenser and other to catch the bottle thread.
  • mysonjonas Feb 25, 2011
    What I meant is you have to use two nuts, one two fasten the dispenser to your top from underneath and then one threaded down to meat the the top of the bottle to give resistance with the three prongs inserted into the bottle. Unfortunately only one nut is supplied, so another nut would have to be hunted down at a hardware store/ plumbing store. Grohe does sell seperate soap dispensers but not individual parts for the dispensers. Grohe U.S. number is 1-630-582-7711
  • LeeT
    LeeT May 14, 2014
    My expensive Grohe soap dispenser leaks soap every time I fill it. It is because the bottle just hangs on 3 prongs and the bottle is not fastened to the unit so when you fill it, any soap that goes above the loose hanging bottle drips off the side and down into your cabinet. Whoever engineered this is clueless. There is only one nut that is supplied to fasten the head to the counter. There is not other mechanism to fasten the bottle other than the 3 prongs. I discovered this by chance when I saw a puddle of soap in the back of the cabinet after one year of use.
Anonymous
SOURCE:
Grohe soap dispenser 28.857 leaks
Take it apart and clean it. If that doesn't work consider replacing it.
Nov 30, 2013 | Grohe Deluxe L Soap Dispenser Finish:...
I have a Grohe soap dispenser and it has quit working for me. It is as if it gets stuck after you push it down and it seems to leak the soap out of the bottom part of the dispenser getting soap all over...
Sounds like there might simply be old soap caked on the inside of the dispenser head and feed tube. Best thing to do is have a sink filled with HOT water and just put the head portion in there to soak for a while. This should loosen the old soap enough to either dissolve or at least get it moving again. You can also take what soap is still in the dispenser out and put in another container, taking time to rinse the container with hot water as well and then filling it with hot water as well to test the pump action of the head, again using this action to help clean the insides of the pump. Short of this doing the trick, it may just be time for a new one. Good luck.
Aug 26, 2010 | Grohe Satin Nickel Soap Dispenser...
Dispenser will not press down
Unfortunelately for you, Grohe, does not offer pump head replacement to the best of my knowledge. The entire pump/bottle therefore will have to be purchased. You didn't mention what finish you had so if you plan to stay where you are for a long time I would suggest you look at the Rohl soap dispensers as an alternative. Their warranty is for 10 years and you can run a 3/8" I.D. vinyl tubing from the pump down to any size jug of soap you want under the sink and never have to refill it again from above. The finish might not be a match however.
May 28, 2010 | Grohe Satin Nickel Soap Dispenser...
My grohe soap dispenser won't pump out any soap.
If the soap dispenser is not pumping the soap then the soap is to thick. You need to then the soap down some so it will pump.
Apr 01, 2010 | Grohe Satin Nickel Soap Dispenser...
Soap leaks from dispenser after use
sounds like a bad valve in handle, might be cheaper to just replace hadle buy the same one and just put in top that way you don;t have to climb under sink and loosen bottle
Jul 09, 2009 | American Standard Contemporary Kitchen...
Soap Dispenser leaks soap onto counter
maby minor crack between the the treds on the bottle that screws in to the pump or a crack in the bottom of the pump and you may not see it because the pressure of the pump isint in the bottle when you un screw it tot look at it
May 17, 2009 | Grohe Satin Nickel Soap Dispenser...
Bottle under Grohe soap dispenser leaks down to cabinet
Pull the dispenser out the top and have someone hold the trim above the counter while you tighen the bottle down below.
But the real problem is the retaiher nut which hold the dispenser in place is loose. Remove the bottle underneath ( it unthreads) and tighten the nut that you see just above the bottle. This can be a tight spot and you may need a basin wrench.
Please rate this response and Good Luck, Phil
Dec 27, 2008 | Grohe Satin Nickel Soap Dispenser...
Soap dispenser leaks
You can fill these 2 ways.You can pull out pump from top,at sink , and squeeze soap in .Or you can unscrew bottle from under sink and fill, I'm thinking that your bottle is loose under sink, or the plastic neck has a hairline crack. Im not real clear on where the soap is comming from.Thankyou.
Dec 11, 2008 | Grohe Satin Nickel Soap Dispenser...
Grohe Satin Nickel Soap Dispenser... Logo
1,625 people viewed this question
Top Grohe Home Experts
Mike
Derek Bannister
Derek Bannister
Gene Haynes
Are you a Grohe Home Expert? Answer questions, earn points and help others
