Hello there
Please read the entire solution i have provided below ok
It won't bake or broil
If
neither the oven nor the broiler heats, but the range burners still
work, the clock may be set for a timed or self-cleaning cycle. Check to
be sure the clock buttons and knobs are set properly. If your clock has a
knob that says "push for man(ual)," push the knob in and try heating
the oven and broiler again. If they still don't work properly, you
probably have a defect in the thermostat, selector switch, or common
wiring.
Note...
If the oven doesn't have a separate bake/broil/etc. selector switch,
the problem is often with the thermostat. It's not easy to check the
selector switch or thermostat for proper operation. If you suspect a
problem with either of these, call a qualified appliance repair
technician.
