Question: Did it ever work? Is it only recovery from sleep? Will it boot normally if you unplug the computer while it is on (forced crash) and then restart. Will it boot in Safe mode? Getting stuck at the welcome screen indicates a driver not loading properly. Since the display does not work, likely the video drivers. Update with the newest driver from Nvidia for your system. Windows XP has had problems in the past with recovering from power management settings like hibernate and sleep.
https://www.geforce.com/drivers
SOURCE: PCI video card not working in XP, T1090 emachine
Have you disabled the on-board video, if not you will have a conflict between the 2
SOURCE: Need help with new AGP video card for T3092 E-machines desktop
You should go in to your start-up bios and ensure the on-board video is disabled. The computer will auto-detect the video card but if the on-board video is enabled then it will cause a conflict. Let me know what happens. Good luck.
SOURCE: have emachines T6528 graphics problem
if it doesn't boot at all .( this is the reason that you see that message on the screen it means that no video signal came out from the computer ) ..try to change the cable that leads from the pc to the monitor first ...and if the problem its still on ...it have to be something related with the Ram memory or the CPU ....cause these 2 are the only things that can make a system to do not boot at all ...if any other device will not work ..the pc will still boot to bios ..or will still show the devices it finds on start ...even if is not able to succeed with the operating system boot...
so ...either it boots and you can not see anything cause the cable its damaged...( very possible cause this is the case it shows that message ...when the cable its shorted ..or unplugged ) or it doesn't starts at all cause of the memory or CPU ...
SOURCE: eMachine Video Card upgrade
Ok so are you getting video from the card? Look in system information and see what graphics hardware the computers says is installed. Are you replacing a video card or did you add a card to the system? If you are adding a card make sure that you change the settings in the BIOS to boot first on AGP/PCI-E express slot. Make sure that fast write settings and bus speed settings are compatible with your card. For example if you purchased a 8X AGP card and your computer only does 4X the card may not work. Double check that you are trying to install the correct drivers for your card and operating system.
SOURCE: e-machine t6212 won't boot
If you get only one BEEP at boot then the computer is working..
Do you have a 2nd monitor to test with?
if it BEEPS more then once...
pull out your mem chips and test,,
If itt works them one of the mem chips are bad if not..
pull out all pci cards and test.. if it works its a bad card...
if not unplug all HD and CD roms and test.......
If not fixed yet it maybe a onboard video problem...
But IF you put a video card in b4 the problem started then your bios may have auto set it sellf to PCI/AGP mode.
Check bios setings,, look for onbord setings for the video
Testimonial: "This answer is a good procedure."
