Fridge and Freezer not cold, compressor not coming on
Freezer light bulb works but Fridge Light bulb doesn't work and the compressor does not come on or make any noise. The bulbs work fine but there is no power to the fridge light bulb socket.
Bad news for you. I've had the same symptom. The problem was compressor. It seem it will not work longer as about 5 years. To buy another one and repair was expensive. I have now new fridge similar to this but I hav for compressor 10 years waranty.
the higher the number on a fridge the warmer it is so setting it to 1 is close to 0C
when working on a fridge or freezer always turn it off at the wall
if the fridge is keep cold but not cold enough set it back to say 3
if the compressor is running and the back fins / wall is hot then the fridge is working
use a piece of paper between the door seal and the fridge edge to ensure that it is sticking to the fridge and sealing off properly
What you are hearing is most likely your compressor cycling on the overload due to drawing excessive amperage, You will have to have it checked out by a tech
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Check the door switch to see if is working and try another light bulb or try the light bulb somewhere else to see if the light bulb is good. Check to if vent holes coming from the feezer are blocked by something in the fridge. This will make it feel like your fridge is not working.
if i read the english right, the compressor runs but the freezer fan only runs for a short time. no fan then no cooling.
there is a fan stat so that the fan only runs when the evap is down to temp. this may be faulty. also on some hotpoint, the fan switches off when door opened. check door switch operating ok. this may also explain problem with fridge lamp
