Knowing your breadmaker's loaf capacity will enable you to find recipes of any variety on the Internet for free.
It will also keep you from adding too much ingredients which could cause dough to over-rise and spill onto the heating element.
Remove your bread pan from your breadmaker. Using a one-cup 8-fluid-ounce liquid measure, fill your bread pan with water. As you do, count the number of cups it takes to fill your bread pan to the very rim.
Generally speaking...
If your bread pan holds 7 & 10 cups to the rim then you have a 1.0 lb or 500 g loaf pan
10 & 11 cups to fill = 1.5 lb (700 g) loaf pan
11 & 13 cups to fill = 2.0 lb (900 g) loaf pan
13 & 15 cups to fill = 2.5 lb (1250 g) loaf pan
15 & 17 cups to fill = 3.0 lb (1350 g) loaf pan
A bread recipe for use in a 1.0 lb (500 g) breadmaker should never exceed 2-1/4 total cups of flour.
1.5 lb (700 g) = 3-1/4 c
2.0 lb (900 g) = 4-1/4 c
2.5 lb (1250 g) = 5-1/4 c
3.0 lb (1300 g) = 6-1/4 c
Warning: When testing a new bread recipe it is always best that you not leave your breadmaker unattended. Stay close by to monitor its progress from time to time.
Did this answer help? I hope so. Please rate it as soon as you can. Thank you.
Here is how you determine the size of loaf you can bake in your machine. You need to determine the capacity of your pan. Fill your pan with water and measure the cups added so you know how many cups of water are in the pan when it is full to the very top. Here are the conversions:
1)If your pan holds less than 10 cups of water you can make: a 1 pound loaf
2)If your pan holds 10 cups of water you can make: a 1 pound loaf and a 1.5 pound loaf
3)If your pan holds 12 cups you can make: a 1 pound, 1.5 pound, and a 2.0 pound loaf
____________________________________________________________________
This is rare, but if you pan holds 14 cups or more you can make all the above plus a 2.5 pound loaf
FROM ANOTHER SITE:
To find your bread machine pan size:
Fill the bread pan with water and measure it out in cups
Less than 10 cups of water = 1 pound
11-13 cups of water = 1 1/2 pounds
More than 13 cups of water = 2 pounds
