SOURCE: Philips 37PF7320A 37 will not turn on
moswt of these i have come accross is either an SSB(small signal board) or a logic board. in rear cases it even requires the replacement of the panel unfortunety ther are a number of test that need to be done on the unit to figure which one it is and i dont recomend you try them yourself.
SOURCE: Red light flashing
ctf1800,
I would love to have that service manual. My Philips 37PF7320A died 4 days ago with the typical 1-4 blinking lights. The fuses are fine but I found a 100 ohm 1/4 w resistor that was dead and replaced it, but no change. Now I have looked closer at the "dead" resistor and after the brown-black-brown and there is a poorly applied green band before the gold one, so I'm not sure what I have. I guess I need to get a high resistance tester off eBay.
[email protected]
SOURCE: 37PF7320A 37 problem hooking up dvd
Connect the DVD to the back of the set on AV2 red white and yellow rca cable . Then to the other end to the DVD red white and yellow. Turn the DVD on and press play. On the tv remote below the number 7 there is an AV button. Press that button and put the tv to AV2. Your DVD picture should be there.
SOURCE: Philips 50 Inch Plasma Model 50PF7320A/37 will not turn on
Commonly it's going to be a power supply related problem. The two boards that need to be looked at is the Main Power Supply Board or the power supply board for the screen. The one that powers the screen, some manufactures call it a Backlight Inverter Board.
If you have some electronic experience, you can sometimes find a Service Manual for the TV over the internet for less than $20. It will have the all resource material for repairing your TV model. It's just the matter of replacing the bad part on the circuit board.
SOURCE: Hi, I have a Philips model 37PF7321d/37, 37 inch
The power board numbers you need to search for on eBay is 310432847531 or 310432838621 - they are compatible according to Philips.
