Question about GE XL1800 1100 Watts Microwave Oven
My Microwave continues to run unless door is open. I do not think it is heating though when I shut the door. When I close the door and push buttons nothing happens. I get a high pitched sound when I press keys. When door is open and I touch keys. I get his nosie like a conection is trying to be made a chattering sound. Not sure if I have a key pad problem, door latch or something else.
    Sergeant:
  • 268 Answers
The high pitch sound to me may be coming from the speaker on the main circuit board. Try to unplug for a few minutes, reset clock time and then try again. If same issue, may need new PC board. When you say Microwave continues to run are you meaning the Turntable is turning and the fan running?? Or is it just timing down. Almost never does it actually keep heating. On GE units I mostly find bad door switches will cause a back feed and make the tray turn and the cooling fan for the mag to run. To see if that is the problem You have to look at the door switches behind the front panel on the left side and see if any of them have any browned connections on the terminals where they push ontl the back of the switch. That will cause the fan and turntable toi run, but wouldnt cause a high pitch squeal. These companies use switches wtih small 3/16 terminals that dont give a good enough grab on the switch, they get loose and hot and make the switch go bad. I replace that switch with a switch with 1/4 inch terminals and runa short section of Hi temp wite to it and it wont go bad again. Just cheaply made!! Also I guess the squeal could come from the turntable motor area. So By fixing the switch problem it could fix your squeal. With nothing else running you may be able to hear motor and coupling noise you couldnt hear before.
Posted on Aug 18, 2017
6ya staff
SOURCE:
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: microwave seems to turn on when door latch is opened
What's happening is you are activating one door switch a little before the other, and that is causing your light, fan, and turntable to come on. The plastic parts are not perfectly rigid, so they flex a little when you press the button, and that causes the lag to be more apparent. Even if you press the door open faster and look really close, you may notice the light, fan, and turntable coming on for a split second. That's perfectly normal. The relay on the control board must also be turned on before it will actually be cooking.
Posted on Feb 23, 2007
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: GE JVM240 microwave - shut door, fan runs,can't set timer or cook
The "main" relay on the control circuit board is stuck (shorted) and needs to be replaced.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Dec 02, 2008
Anonymous
  • 9 Answers
SOURCE: Microwave door not closing properly so will not work
Throw it away and get another microwave
Posted on Aug 07, 2009
MNfisherman
Nate Stansfield
  • 11896 Answers
SOURCE: The key pad doesnt work, had it less than a year.
The panel may have a short or need to be tested for replacement. You should try and leave unplugged for 8 hours so power supply can fully drain power and reset microwave
Posted on Aug 25, 2009
Oloyede Monsuru
  • 1417 Answers
SOURCE: Team, I have a GE JVM1630 BK01 Microwave Oven,
hello,
There is no reset button for this type of problem to be properly solve.
this type of problem can be view from two angle here below
1) From the wall power supply connection
2) from the oven wires connection to the panel or unit control
What this could indicate from your explanation is that there has been a bring of wire from the power control connected to the element (heater), what you are to do to solve this problem carefully, is to carefully unscrew the oven then trace the wire from the main power supply down to the control switch (panel or unit) after you most have unplug it from power supply to see if there is any of meant wires around if you are un able to trace any loose/bad wire then couple it back to it position and trace the problem to the main power supply from the wall mean that a partial contact from the wall unscrew it with a screw driver (technician tools )fix it up and then couple it back with this the problem of continuous will be solve.
thank you and thanks for using fixya.
Posted on Sep 11, 2010
Why microwave won't stop running unless door is open ?
Is it actually heating or just making noise and acting like it's heating? (put a cup of water inside and close the door.) IF it's actually heating, then you have a shorted relay on the main control board, and you will have to replace the board. IF it's just making noise like it's working, but it's not heating, then the problem is 1 of the door switches is not working right (it's either stuck open or stuck closed).
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Aug 16, 2014 | Whirlpool Microwave Ovens
Roper Microwave fan won't shut off
THE FAN AND MICROWAVE TUBE RUN OFF THE ELECTRONIC TIMER. OPENING THE DOOR SHOULD SHUT IT ALL DOWN AND WHEN YOU CLOSE THE DOOR AGAIN YOU SHOULD NEED TO PRESS THE START BUTTON AGAIN. IF NOT, ITS SOUNDS LIKE AN ELECTRONIC RELAY IS LOCKED CLOSED ON THE TIMER BOARD.
Aug 28, 2007 | Sharp R-1610 Microwave Oven
Microwave keeps running with door open
I'd say the door interlock switch has failed, and supplies a connection when it should not. Microwave ovens can be dangerous to anyone poking around inside, even when unplugged, so get a quote from a service tech. You might find that parts+labour is almost as much as a new one.
Microwave radiation being released through an open door is also a hazard, as it is known to cause eye cataracts, so don't get near if the oven does this.
Nov 19, 2013 | Panasonic Inverter Countertop Microwave
GE Microwave will only run about 3 seconds, then shuts off. I've unplugged, let it sit and tried again. Same thing. Help!
I have a workaround for you, that works for other brands. I am not sure if it will work in your case though. Pls try it:
- It seems that the door closing sensor is not working well, so it might think that the door opened.
- Once you have this problem, open the door and then close it again.
Normally it should work...
Nov 21, 2012 | GE Microwave Ovens
Kenmore elite microwave 721.80833 stops cooking intermittently
Check the door switches if one is bad it may think the door is being opened and stop the unit from running. If it is from a bad connection it will get worse as it gets hotter while running.
Oct 04, 2017 | Kenmore 80809 Microwave Oven
My GE Spacemaker (HVM1540) will not turn off. Often when we use it and open the door to get food out, then we reclose the door and it continues to run. Even after hitting Clear/Off it continues to run...
Ok I have the same model and mine was doing the same thing. Apparently this model has a reputation of problems with the control board. I played with mine for hours and here's what finally worked: unplug the unit (or shut off the breaker--whichever's easier for you), take a dry cloth and wipe the door latches and control board clean of any residue. Then with the door still open, gently jiggle the control board by firmly grasping with your hand. Power up your unit again. This worked for me. The control board is really fussy and should be clean and free of any dust or residue. I notice this happens again when it gets dirty so I repeat the process and it's been working.....so far!!!
Jan 10, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Jvm1870sk04 GE profile microwave will not shut off unless the door is open. Unplugged , pushed off/cancel continues to run with door closed. Any solutions?
Hi, Main control board bad...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a 10 year old MH7130XE Whirlpool microwave oven. The oven and key pad both work, and the oven heats just fine. The problem is the oven begins running as soon as you open the door...without pushing...
I'm assuming you mis-typed and meant the oven begins running when you SHUT the door and stops when you OPEN the door. Please tell me this is what you meant! If the microwave oven runs with the door open, UPLUG IT IMMEDIATELY AND DO NOT USE IT!!!
If the oven begins running without pushing the start button then the controller is bad or the Start button is worn out and making contact without pushing it. (Most likely it is your controller.) Generally, it is not worth the cost to replace the controller on a 10 year old microwave. Probably time for a new one.
But if you want, you can call Whirlpool and see what they suggest at 800-253-1301.
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 18, 2009 | Whirlpool MH7130XE Microwave Oven
Microwave will not turn off. it runs and runs when door is shut stops when door opens but if you shut the door again it just runs unless i unplug it. It will not heat light is on clock works .will not...
This is usually caused by either a bad door switch or a loose door switch mount, or sometimes a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 12, 2008 | Microwave Ovens
Self start when door closes
if electronic control, one of two things come to mind. 1)your toutch pad is defective.replace it. 2)you electronic board has a leaky component.not very likly though. believe it or not, ive seen it start before by itself then i noticed a large quantity of bugs inside the glass which i realised triggered the microwave 0ff.
Jul 23, 2007 | GE JVM1460SA Microwave Oven
GE XL1800 1100 Watts Microwave Oven Logo
157 people viewed this question
Top GE Microwave Ovens Experts
Poppa Maddo
Poppa Maddo
William Miller
William Miller
Jimmy
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
