Hi my son dropped his ds lite yesterday and now will not power on at all. Was just wondering if there may be a fix for this or if we should just get a new one?
Thanks
I bought a ds housing shell and I want to know how I can take it apart and put the housing shell onI bought a ds housing shell and I want to know how I can take it apart and put the housing shell on
AnonymousMay 26, 2008
When turned on top screen flashes then shuts downWhen turned on top screen flashes then shuts down
If you want get some tools and take the ds apart.make sure all the pieces are straight and are put together right.if there not straight,make them straight.if there not put together,put them back together.Hope it works.
this happend to my sister it dont work anymore had to get a new 1 when ever it dropped it broke a little chip thing inside take it to a gamestop take it appart see what the problem is
Well go to a nearby GameStop they fixed my DS lite when it wouldnt charge with the charger the reason was it was old so i needed a new one anywhoo when the screen comes on it says NENTENDO DS LITE well mine says lite since it is a ds lite well you tap the screen with your pen and the menu is there or this could be because you (A) dropped it
(B) got it wet
(C) handled it roughly
hope this helps
~Queen of Spades
@JoepIt, you have a defective LCD screen. Could be upper of lower (I thing for 99% the upper).
@pietras1422, on the mainboard next to the power-switch, there is a resistor. If could be loose or is missing completely. Problem will occur when the DS Lite is dropped to the ground
The described problem you have happens normally if you dropped the DS Lite. So thats why Nintendo states that it must have been dropped. It would be difficult to proof that it not has been dropped.
I think it can be fixed but by an expert not by sombody at home, if you need experts in that area you can look for them in fixya
http://www.fixya.com/ServiceCategories.aspx
I think it's a wire problem and shouldn't be to hard to fix it also should be cheap.
My son's DS has stopped working as well. When you turn it on (plugged in or not) the bottom screen flashes gray and then goes black again.
I switched my other son's battery into this DS and the problem remained so I know its not the battery.
Help!
