I cannot see the message i typed after entering it. the scripting options is set but still cannot see anything.. pls help.. thanks
Slurpee
try this guys!
FIRST CLICK>START>CLICK ''RUN'' TYPE REGEDIT PRESS ENTER
NOW >>
HKEY_CURRENT_USER >.> Software >> Microsoft >>Windows
>> CurrentVersion >> Internet Settings >> Zones >
there will be folders like
0 1 2 3 etc
you might see a box kind of folder there before that zero folder delete that .
Thank you so much !
You're just a talented guy !
And it does not hurt !
Works great !
THANKS SOOOOOOOOOOOOOO DAMN MUCH!!!! OMG!
Thank you my friend...I tried other command line solutions butit didnt work..but when i tried your solution it worked ..result was seen only after restarting the machine..I am very grateful to u ..u solved my problem which was pestering for a long time...Big HUG!
nice job man!!!!!!!! thank you so much.........keep it up!!!!!!!! ^_^
NICE JOB MAN!!!!!!!......IT HELPS A LOT..........
eag_1215 Thanks a lot dude. Your really a computer wizard anyway where did you get this. Is this from your own?
I am sorry friends it doesn't work.. I found a folder called L maintain 3 sub folders.. I delete it.. but nothing happened.
However thank you so much .. I will try to do something else
Have a nice day
two thumbs up men.. your the man
Thanks a lot buddy ....
Thanks thank u very much
thank you very much, got it man, you are great
Awesome dude! Where did you find this solution?
Great work! Keep it up.
Whao!!! You are a STAR. I really don't know what to say other than thank you. instructions are very easy to follow. Thanks a lot
kya baat hai reeeee...ye IT ki dunia ke betaj badhshah kon hai ree..wakai u r great yarr..n thanks alot..n big huggggggg>:d<>:d<>:d<>:d<>:d<>:d<>:d<>:d<
works great thanks yo im from guyana
God bless you!
God bless you!
thank you ssssssssssssssss oooooooo much.you are great
This is the best solution.. tnx men
Thanks a lot haiiizzttt it is really help is tried this step below and it not works on me but your steps works thank you very much!!!!!!!!!!!!!!!1
STEP -1
go to Start Button - Run - type regsvr32 jscript.dll - then press OK
STEP-2
go to Start Button - Run - type regsvr32 vbscript.dll - then press OK
Thank you very much,it was very helpfull,000
Tasin
Nice! Thanks worked for my ym10
Thanks alot buddie. u deserve wid hug :-)
Hi buddy
Thank you so much for this valuable tip.. I was troubled by this error a lot. Your tip helped me to solve.. :D
Now my messenger works... :)
Thanks a lot
Thank You Man....
It worked for me ...I did not have messenger for last 6 month ... and It works today ..
I find a folder before 0 Folder ..It looked like a rectangle ..I deleted that ...and after re logging it works.
Thank You again
If you tried this solution:
STEP -1
STEP-2
after doing so this message appear: "Regsvr32 Error 0x80004005" (usually in windows vista). And advised youo to logged in as an administrator.
Use this approach:
close your yahoo messenger
go to: c:\windows\system32 and look for the "cmd.exe" icon
right click the icon and click "Run as Administrator"
a command black screen will appear. Then type the following in the commend end line of:
first:::: c:\windows\system32\regsvr32 jscript.dll ,then press enter
2nd:::: c:\windows\system32\regsvr32 vbscript.dll ,then press enter
Now check your messenger. Evrything will be restored back in order.
Regards to all!!!
My pleasure to help everyone.
"Knowledge sharing...brings happiness"
thank you very much.did it well.
i tried that too, but still no use..the same problem remains
Got it. Thank you so much. I fixed two laptops already with this kind of problem.
thanks alot... tht did fix the problem.. now i wish there was a easy fix like that for LIFE!!! lol ;)
Some virus can cause this bug in Yahoo Messenger. Check your Internet
Options, go to Security Tab, and see if there is a new item. Normal
items there are Internet, Local Intranet, Trusted sites, and Restricted
sites. If you see a new item, chances are you were hit by a virus.
To resolve this, open a registry editor (click Start, click Run. On the
Open box, type: regedit and then press Enter). Navigate to the following
key: HKEY_CURRENT_USER \ Software \ Microsoft\ Windows \ CurrentVersion
\ Internet Settings \ Zones
There should only be 5 items there, numbered 0 to 4. If you see a
different one, especially if you see items that shows up as box, try
deleting it. (Backup your registry first). If you were able to delete
that extra item, this might fix the bug, and you will be able to see the
chat messages again in yahoo messenger.
The solution that the "guest" posted
Solution #3
posted on Aug 12, 2008
worked for me after about 8 months, and searching the internet for a fix!!!!!!!!!! thank you so much!!
just a recap.. the solution for me was
Close yahoo messenger
STEP -1
STEP-2
now your yahoo messenger will work normally
I want to thank apprentice for the solution to fix my yahoo messenger.I was not able to send or receive messages and it was very frustrating.I found this website and read through some solutions by other users and since I had tried everything else,I decided when I read apprentice's suggestion of going to Start and clicking on Run and typing in what they suggested for both steps and when I logged into yahoo I found I could send and receive messages again..God bless you!
Best Solution
Guest
Rank: Apprentice
Rating: 0%, 0 votes
STEP -1
STEP-2
Solution #6
posted on Dec 08, 2008
lighthouse27
Rank: Apprentice
Rating: 0%, 0 votes
I
Hey thanks allot....for 1year i hav been searching for solution....now its wrkng..thanks allot 1ce again...
Woohoooo thank u very much GIJoe. i don't why this happened in the first place. if u have time to tell, pls post the cause of such error hehehe so i won't be making the same mistakes again.
I am using yahoo on win 2k, but this does not solves my prob, I cannot see the messages the after pressing the enter.
Thanks
ahmed_ [email protected]
This is a very tricky solution... :) i shouted for joy when i was able to fix it. .. Anywayz, here it is...
Ask your Tech if they have given you Modfiy rights on your Drive C. or you can simply add access permission on Yahoo folder @ program files...
Thats it. :)
GodsGift2Women
Dependng on your Windows version, this will work differently:
Windows XP
Go to Run -> type regsvr32 jscript.dll -> Press Enter key
Go to Run -> type regsvr32 vbscript.dll -> Press Enter key
Windows Vista or 7:
Press The Start button/orb -> In the text box, type run -> Initiate the run program -> type regsvr32 jscript.dll -> Press Enter key
Press The Start button/orb -> In the text box, type run -> Initiate the run program -> type regsvr32 vbscript.dll -> Press Enter key
I hope this solves your problem! Also, if this didn't work, reinstall your messenger client and try again.
Help this is what i got after typing regsvr32 jscript.dll, error code 0x80004005.. =(
Thanx Solution no 5 worked for me....
I saw letter L from folders 0-5 i delete it but nothing happens
Hi! i cant see what i typed in my yahoo messanger and i cant see my replys too
Peace of ... need to format.. wont work..
I am not able to type yahoo id in yahoo messenger b coz the box seems to not activated
Thanks!
Thank you!!!!!!!!!!!!!!!!!!!!!!
Great..instant fix!! Good Job Fixya!!
Wow..thanks alot
thankx evryone for the help super duper fix
hmm. I`ve faced the same problem, but I fallow these steps founded here:http://devicearea.com/2011/02/10/how-to-...
and it worked. It's a very simple procedure. I hope it can help you too.
100% works....thanks...
STEP -1
STEP-2
cant see the messages i type in messenger
cannot see anything that I type or other party posts :( please help
i get logged into yahoo messenger but when i open the window and start sending message the reciever can c my messages n reply me but on my window no messages appear .........it remains blank
my yahoo messenger is working but when i want to give the message to any of my friend which was added in my messenger list,the message window is not appear.it shown blank
I'm the same at problem. i was try uninstall and re install agian but it still not appear my type.
same problem here.. the advice iv seen suggesting changing IE scrip security settings dont fix it either
I have the same problem for Yahoo Messenger Version 9.0.0.2034. None of the solutions shown here worked. Please HELP.
Thanks.
thank you so much problem yahoo message not appear solve
http://www.allfreelancejob.com
chris
i ahve the same problem
I am also have same problem if some one is aware of resolution pls let know
cannot see the message i typed in yahoo messenger 9 and other versions
Same problem. Had to install version 8 because when I installed the newest version on my Vista machine, I could not even see my friend list, so went to previous version. Now I can not see messages I send or those I receive. Very annoying problem.
Messenger session is going along fine and all of a sudden my recipient cannot see anything I am typing. I'm typing away and they cannot see a thing. On their end it shows I'm typing but they never see the message.
i am not able to see my msges which i send and also see the other person's msges... is there a solution
very nice , I got this solution and become excited when I use it . thanks a lot .
have a nice time and life
STEP -1
STEP-2
i tried this solution and it did not work. i can see others what they type and see what i type, but no one can get messages from me beyond the first message they received. i have two other names attached to my same yahoo name account and same applies to those when i try them too. what is the problem and how do i fix it?
cannot see what i have typed on messenger neither can i see what reply i have got from the other person
please advise what to do
thanks a lot
