Hi!
The F1 code means that the Key Pad is defective, the book says that if pressing CANCEL for 10 seconds don't stop the beeping and resets, the Pad should be replaced. I have learned that if you unplug the unit from the wall outlet for a couple of minutes, most of the time the pad will reset by itself.
Good Luck!! Don't forget to rate this post!!
SOURCE: amana stove with F1 beeping code.
Amana is now owned by Whirlpool. The customer service number is 800-253-1301. If you have reciepts (Proof ) of service calls you may be able to negotiate some form of concession. Good luck it can be a frustrating process.
